need help wiht amp install
Old Dec 15, 2003 | 02:58 PM
harrymay's Avatar
ok im puttin an 800w kenwood amp in the max, its a 92 gxe. im very very confused about this install. so far, i have established that i need to run a power cable from my batt, throught the firewall under the carpet, under the back seat and up to the amp. and i also have to run an rca cable from the hu, on the other side of the car in the smae fashion. now what am i forgetting??
is it ok to mount the amp on the box, or should i fasten it down elsewhere. also i was gonna ground the wire besides the spare tire, is this ok.
im really new to this, i only just figured out how to replace my speakers
(and im tooo poor to afford install)
Old Dec 15, 2003 | 03:10 PM
nismos14's Avatar
§è~® f®ÈÄk
u can ground it on the rear strut tower, just scrape off the paint under the bolt. you also have to run a remote wire from the headunit back to the amp.
Old Dec 15, 2003 | 03:36 PM
harrymay's Avatar
i actually dont have to do that, coz my bose is still half hooked up, i still have power coming to the back amps. what about line level control, the amp has this built in, but where do i cut the wire in, if i even have to do that.
thanks
Old Dec 15, 2003 | 03:53 PM
KsuMax's Avatar
Cheesing away...
I mounted mine here behind my box
Old Dec 15, 2003 | 04:06 PM
nismos14's Avatar
§è~® f®ÈÄk
if ur going to use line level control ( i think u mean high level inputs) ur not going to need those rca cables ur planning on or already have run.
Old Dec 15, 2003 | 04:43 PM
harrymay's Avatar
ok, its all starting to come together now, is it ok to mount the amp on the box, i herd that vibrations can screw it up
Old Dec 15, 2003 | 05:42 PM
nismos14's Avatar
§è~® f®ÈÄk
yes thats fine to do
Old Dec 17, 2003 | 12:36 PM
harrymay's Avatar
ok, so it took me 6 hours 20 minutes, but i did it. i trouble with the power cable, it was a little too short, but i went to a welders supply store and got some 4 gauge and now it works great. ive never done it before and i am really impressed with the way it sounds, no fuzz or anything. now all i need to do is dynomat/xorb the trunk so it doesnt rattle anymore
thanks for the help
Old Dec 17, 2003 | 02:11 PM
nismos14's Avatar
§è~® f®ÈÄk
nice, rewarding isnt it?
Old Dec 17, 2003 | 10:16 PM
harrymay's Avatar
yeah, apart that i didnt strip the power cable enoguh, and it came loose today on the way to work, it scared the crap out of me coz my car wouldnt start whenever i found the cable. but im impressed with the results
Old Dec 17, 2003 | 10:19 PM
nismos14's Avatar
§è~® f®ÈÄk
haha same thing happened to me sort of. i was adjusting the placement of my sub, and one of the amps would keep shutting off on me i was like what the hell!! so i pulled the box back out and the ground wire on one of the amps wasn't properly crimped in place!! arg!!! but now all's well
Old Dec 19, 2003 | 10:23 PM
Golden Ice's Avatar
I didn't run my power cable through the firewall and under the carpet, I ran it under the car along the brake/fuel lines under the plastic shield..I used extra heavy duty Forney 4 ga welder cable, and protected exposed sections with reinforced garden hose..I ran my remote wire down the right side, my RCA cables and the wire for the rear speakers down the left side..
It should be ok to mount your amp on the box, as long as you don't do it with a Legacy amp..thats one of the things that caused mine to fry..but a kenwood is a tank of an amp, so you should be fine mounting it on the box..if you can find them though, you may want to stick rubber feet between the amp and box..
Old Dec 20, 2003 | 07:59 AM
harrymay's Avatar
thats a damn good idea with the garden hose. i was thinking about that stuff that they use for the wires in the engine bay. yeah, i got a purdy sweet deal on that setuo though, alone the amp is 2 bills, and each of the subs is 1 bil, i got it for 200, plus i got the box for 30 when it shoulda been 90. and the wiring kit shoulda been 99.99 but i got it for like 45. i love employee discounts
Old Dec 20, 2003 | 04:44 PM
maxu4ia's Avatar
Since you're running so much power (i.e., 800 watts, I would recommend a 1 farad or at least a .5 farad capacitor as well. It will keep your headlights from dimming and you'll get better sound.
Old Dec 20, 2003 | 07:00 PM
harrymay's Avatar
so far im not having a problem with nay power loss, i grounded it out to the rstb, and it seems to be ok, i dont intend to drive around and shake other ppls cars i just want a massage when i get off work
Old Dec 21, 2003 | 10:27 PM
Golden Ice's Avatar
I ran a 1200 watt amp in my '92 GXE with no cap..and I will be again here soon..monday or tuesday..but I have an auxillary battery in the trunk now, so I doubt I'm going to have dimming issues..I might get three 1F caps for REALLY good coverage though..
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
