UPDATE about FM sensitivity with Alpine HU
Old Dec 15, 2003 | 08:58 PM
dracip's Avatar
Hello everyone. 2 days ago I complained about the lack of sensitivity on my Alpine HU
http://forums.maxima.org/showthread.php?t=270841
and I found why. As you may know, there is a antenna amplifier (located in the right C-pillar) that boosts the signal coming from the rear window antenna. To make it work, you have to use the power antenna lead (acting as a remote)coming from your aftermarket HU, and connecting it to the matching wire on your harness adaptor (I found that by looking at wiring schematics of the Bose system : there is a remote turn-on for the antenna amplifier).
When I first hooked up my HU, I didn't bother about the power antenna lead since we don't have one on the 5th gen Max. But tonight I made the test, and voilą ! full of stations coming in on the FM band.
So I hope this will help some of you getting the full potential of your tuner !
Denis
Old Dec 16, 2003 | 08:40 AM
johnnyo319's Avatar
Is there something like this for 4th gens?
Old Dec 16, 2003 | 11:22 AM
BG2K's Avatar
Is this only in Max's with Bose? I have 2k SE w/o Bose, and I don't get any stations on my Alpine.(I mentioned this in the other thread)
Old Dec 16, 2003 | 11:29 AM
Jake9190's Avatar
It would be great if someone could make a writeup or post pictures so people know exactly how this hooks up.... having not seen what the op is talking about, its hard to envision
This would help a lot of people out though. I can report on the 4th gen within the next week when I tear my stereo apart
Old Dec 16, 2003 | 11:41 AM
DougJones's Avatar
dracip,
If this works, you are da' man! I have been living with subpar reception for weeks
Old Dec 16, 2003 | 04:42 PM
dracip's Avatar
No problem, it will work too since the HU must use the same antenna booster.
Old Dec 16, 2003 | 04:48 PM
dracip's Avatar
Originally Posted by DougJones
dracip,
It works very well! As I said, I couldn't catch FM stations in Montreal, about 70-80 miles from home. Now I can hear them easily .
Denis
Old Dec 16, 2003 | 04:55 PM
dracip's Avatar
I'll scan some schematics and explain how it's done. Stay tuned!
Old Dec 16, 2003 | 04:57 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
Denis
damn i wish i would have seen this thread earlier when i installed my headunit i ahd the same probem but figured the same solution out
sorry
-J
Old Dec 16, 2003 | 06:57 PM
DougJones's Avatar
dracip, thanks for the tip. I can now listen to something else besides national public radio
Old Dec 16, 2003 | 08:15 PM
dracip's Avatar
Hello friends,
as promised, here are instructions to do this wiring task
http://maxima.cardomain.com/memberpage/256834/7
Denis
Old Dec 16, 2003 | 10:31 PM
Jake9190's Avatar
Hello friends,
Denis
Very nice. Thank you very much for doing that.
Just curious, but shouldn't this be done in a normal install anyways, or do people neglect this since most cars don't have this function? I was thinking you hooked the blue wire to the actual antenna adapter... doh.
Old Dec 17, 2003 | 06:23 AM
DougJones's Avatar
I normally do not connect the power antenna lead. Well, unless I am installing in a car with a power antenna. However, I'm not a professional installer, but just a garage diy guy so take what I say with a grain of salt
I have been doing this for quite a few years though.
Old Dec 17, 2003 | 06:54 AM
dracip's Avatar
I had never installed a radio before, but I had good instructions, and when I saw the power antenna lead, I left it alone. If I hadn't read the OEM radio schematics, I wouldn't have figured that out. So unless a car has just a single whip coming through the fender, maybe we will always have to use this remote wire since more and more cars have their antenna on the rear window, and they probably need some kind of signal booster because I don't think window's imprited antennas have the same gain as a vertical one (if I remember correctly, it has something to do with the body of the car). Maybe a pro installer can confirm that to us (Pearl96Max ? )
Denis
Old Dec 31, 2003 | 10:14 PM
speediq99's Avatar
Can someone help me identify the correct 'blue' wire for the power antena turn on. There is a blue wire but according to this diagram, http://maxima.theowensfamily.com/audio.html but it is for the read passenger side speaker.
Thanks,
Mike
Old Dec 31, 2003 | 10:15 PM
speediq99's Avatar
Forgot to mention, this is for a non-bose Max 2003.
Thanks,
Mike
Old Jan 1, 2004 | 06:58 AM
dracip's Avatar
Thanks,
Mike
Hello Mike,
your diagram shows that you have to use the green/white wire IF you want to use this wire directly by tapping or splicing it (this wire ''belongs'' to the Nissan harness). I didn't want to do this, and that's why I used a harness adaptor, like this one
http://www.crutchfield.com/cgi-bin/S...y=L#morephotos
to avoid splicing into the Nissan harness. The blue wire I was referring to ''belongs'' to the harness adapter. In the following picture, you will see that most wires' colors are different (harness adaptor on the left, Nissan harness on the right) :
The blue wire on the upper left harness is the one to use (for this harness brand) to crimp/solder to the corresponding wire on your aftermarket HU harness. For DIYers like us, the harness adaptor help make the job easier and less confusing. You can buy the harness at your local sound shop, and even Wal-Mart has it.
Denis
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Robert Schneeweis
Jan 11, 2017 06:47 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
