Need Stealthbox amp help and more.
Old Mar 1, 2001 | 03:30 AM
tony
Howdy All:
I am getting a Pioneer 8200r HU, and a JL Stealthbox with one 10W6 300watt subwoofer wired at 3 1/2 mono. I am curious what amp I should bee looking at?? Should I look at one just for the amp and if so anything in particular?? In searching it seems that the 10W6 has somewhat special requirements??
Also I may end up getting components for the front. Should I maybe just look at a 4 channel or would two amps be a better way to go??
The car is a 96 Nissan Maxima.
Any and all thoughts and opinions would be appreciated. Any recomendations for front components would be great too.
Best regards, tony
Old Mar 3, 2001 | 08:09 PM
jmax
The W6 series from JL use a dual 6 ohm voice coil. They can be wired in series - 12ohms or parallel - 3 ohms. This presents a problem when bridging an amp because you need an amp that is 1.5 ohms stereo stable. This nocks most of the affordable 4 channel amps out of the running. A small mono-block sub amp would work well for just the sub, or a more expensive amp designed to be run at low impedance.
Old Mar 4, 2001 | 11:10 PM
jsmiam
Most 5 channel amps (4 channels plus a sub channel) are stable into 1 or 2 ohms for the Sub channel. And, the 4 regular channels can be bridged into two channels. The flexibility is nice
Old Mar 11, 2001 | 12:22 AM
SWEETSOUND2001's Avatar
i would recommend such an amp as phoenix gold xs2300 , that will give you around 350 watts bridged into 3 1/2 ohms or mtx thunder 302 will be nice too, or rockford fosgate punh 360a2 or other similar amp.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
