remote start problems HELP!!
Old Jan 1, 2004 | 11:13 PM
mb1's Avatar
mb1
I bought the crimestopper cs-2015fm. I cant get the remote start to work on my car. I have a 98 maxima, 5spd. Everything is connected properly I beleive. When I attempt to remote start the car, I hear a noise in the engine bay, but the car doesnt start, after usualy 2 "attempts", the remote notifies me that the car is started. Do I need a clutch bypass? What could be the problem? I tried the timed crank with the same results.
Old Jan 2, 2004 | 06:40 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Did you try pressing the clutch in when you remote start it?
Old Jan 2, 2004 | 07:18 AM
mb1's Avatar
mb1
tryed that, and it did the same thing. The noise in the engine bay is nothing like I heard before. By the way, I am using the tachless mode, and I tried the timed crank. does ignition2 have anything to do with this?
Old Jan 2, 2004 | 09:58 AM
Pearl96Max's Avatar
there is only one ignition wire, but there are two starter wires. You did hook up noth correct? Also ALWAYS use a tach especially if its available.
--Don
Old Jan 3, 2004 | 02:26 PM
mb1's Avatar
mb1
--Don
ok, I found the second starter wire.
it starts when I hold the clutch down.
how do I bypass the clutch? I'm about the take the switch off to see how it works. any suggestions?
Old Jan 3, 2004 | 09:00 PM
Pearl96Max's Avatar
I dont remember the color, but it is the one that reads ground when the clutch is depressed. You can bypass it via a relay Only when engaging remote start. Use the "status" lead off the alarm or you can also use the factory disarm wire.
--Don
Old Jan 6, 2004 | 02:03 PM
mb1's Avatar
mb1
--Don
thanks for your help. I finnaly got everything working. The clutch bypass was alot easier than I thought. All I had to do is run the factory alarm disarm wire(ground when remote start) to the yellow/red wire on the clutch switch.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
