Question about system setup
Old Mar 3, 2001 | 01:00 PM
wesley
I'm getting the JL Audio Stealthbox with the 10w6. Where should I mount my amount, and how do i mount it? Also, how much power do you think I should give the sub (rms amp power?) Thanks
Old Mar 5, 2001 | 02:03 PM
krell
I though the Stealthbox mounted around one of the wheel wells in the trunk....
As far as power I have a 10w3 that I'm running off a Alpine V12, around 240W bridged RMS. This seems to do pretty well.
Old Mar 5, 2001 | 05:08 PM
CanuckAMP's Avatar
The stealthbox mounts in a specific location in the trunk, in the Maxima it mounts on the left side of the trunk. as shown in this pic.
http://www.jlaudio.com/stealthboxes/images/maxima.gif
For an amplifier power consider something that will deliver a clean 300W-500Wrms in bridged mode. The 10W6 has a power handling of 300W or 150W per coil. This is a dual 6 Ohm coil sub so when wired up in parallel the amplifier it will deliver a 3 Ohm nominal load. Most 4 Ohm stable mono bridgeable amplifiers should be ok with this load presented.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 7, 2015 07:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
