using automotive subs at home?
Old Jan 15, 2004 | 03:26 AM
dko's Avatar
dko
duck and cover
i'm re-doing a sub i put together for my home audio setup and i'm on the lookout for new drivers. i'm going to be using a cerwin vega 300W RMS plate amp and am shooting for a compatible driver. that being said, i can't help but notice that car audio drivers are so much less expensive in proportion to their power (watt per buck, so to say). is there any reason why using a good quality car sub (infinity kappa perfect 12") in a properly designed box at home would be worse in any way than a driver made for home audio?
a driver is a driver is a driver, right? i've seen infinity's home theater subs and the cone design and materials look suspiciously close to their car audio stuff. the kappa is 350W RMS @ 4 ohm and 1400W peak with a 15mm excursion, 96dB spl and reportedly great SQ. it's also gotten wonderful reviews everywhere i've checked and i can nab it on ebay for under a hundred bucks.
does anyone know any reason i should shell out two or more times more for a jbl/klipsch/whatever home audio woofer rather than that?
Old Jan 15, 2004 | 08:57 AM
jmax
There are hundreds, correction, thousands of home audio DIY (Do-It-Yourself) subs on the market.
Car subs typically have a higher FS and a few other design differences to account for being used in a tiny room. You can still design an optimal enclosure. It's just a matter of knowing the math and possible costs / benefits of different alignments. Having a good computer box design program is a good idea as well. WinISD is by far the best sub $1000 program I have used, and it's free.
http://www.linearteam.dk/
Here are a few other invaluable resources for the audio enthusiasts and speaker builder. Many of these suppliers / speaker builders also have forums.
http://madisound.com/
http://partsexpress.com/
http://acoustic-visions.com/
http://www.northcreekmusic.com/
Old Jan 15, 2004 | 10:22 AM
Maxima Dan's Avatar
Car audio suds are generally designed with an appropriate Fs to work with the cabin gain in cars not room gain in a home. Try Adire audio. The Shiva woofer works great in both cars and homes and is reasonably priced.
http://www.adireaudio.com/diy_audio/...dire/shiva.htm
125.00 direct from Adire. You would need about 3 Infinity subs to produce the same SPL at 20Hz.
Old Jan 15, 2004 | 10:19 PM
BSwithTF's Avatar
Adire has some awesome DIY projects as well. I read for hours one night on their site.
Old Jan 16, 2004 | 12:05 AM
dko's Avatar
dko
duck and cover
thanks a lot guys. i'm very seriously looking at the adire, especially because it is less than a used infinity and is better in every way. it's even plain black without flash, so they'll never know what hit them
if anyone needs any more convincing, look here:
http://www.audioreview.com/Subwoofer...x.aspx#reviews
oh, and while we're on topic, is there any website that has a long, detailed writeup on all the theory? it'd make for an interesting read and i'd love to know how my box stacks up.
Old Jan 16, 2004 | 09:01 AM
jmax
There are too many sites with theory info. Try a few of the links you already have. And download WinISD. The help section has most of the theory you will need for a while. Also stop by your local library and read Vance ****asons Loudspeaker Design Cookbook. That is where most people get the introductory speaker design education. Once you read that if you want to know more, there is a lot more to know.
But definitely start with the Adire tech files, Win ISD, Northcreek, and the Madisound and Acoustic-Visions forums.
Apr 16, 2020 05:15 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
