Audiobaun... neon light
Old Feb 14, 2004 | 08:12 PM
RickCardinale's Avatar
I reaently got and Audiobaun box with 2 12" inside of it with a neon installed in my car and in order for the neon to work i need to hook it up to a 12 Volt section of my car. Where is the best place to hook up the wires so the neon light would work. Thanks for the help
Old Feb 14, 2004 | 08:21 PM
AscendantMax's Avatar
why not tap into the power cable that feeds your amp?
Old Feb 14, 2004 | 08:38 PM
how would i do that and wouldn't that blow the fuse in the amp?
Old Feb 14, 2004 | 10:14 PM
nghtfthlngknvs's Avatar
nah, that neon won't even draw an amp i would bet. you'd be fine. as for connecting it, it's simple; jsut attatch the neon's power wire to the power wire going into your amp.
Old Feb 15, 2004 | 07:42 PM
probmxstyle's Avatar
Not the power wire from the battery, then the light would be on all the time. Hook it to the remote wire off the h/u instead.
Old Feb 15, 2004 | 07:47 PM
aah good point. i must not have been thinking :P
Old Feb 15, 2004 | 08:54 PM
but you can switch the neon on and off
Old Feb 16, 2004 | 05:08 PM
If i hook it up to the wires that go from the box to the amp wouldn't it neon shut off when i turn the car off
Old Feb 16, 2004 | 05:21 PM
oh, so there's no on/off switch on the unit? (I don't know much when it comes to neons)
Old Feb 17, 2004 | 02:46 PM
the way the neon works in the box is that it lights up every time that the bass in the song hits. so when the song is not playing or the car is off the neon won't light up. so couldn't i just hook it up the wires that go from the box to the amp?
Old Feb 17, 2004 | 04:22 PM
trubd's Avatar
dude i got the same type of box from audiobahn
this is what you do... Pos wire from neon goes to turn on lead on amp. neg wire from neon goes to ground lead on amp.. and yr done !
btw wt model do u have
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
