wiring amp wire to battery
Old Feb 19, 2004 | 03:15 PM
jtm087's Avatar
Are there any predrilled holes through the firewall where I could run my amp wire that anyones knows of, or do I have to drill my own holes. I have A 96 SE, and pics would be great if possible>
Old Feb 19, 2004 | 03:18 PM
BLACKonBLACK98's Avatar
Former Vendor
i drilled my own. the only whole i could find was for the hood release, but you need that. i just drilled the hole right next to it , and ran the wire with the hood cable.
Old Feb 19, 2004 | 04:22 PM
jtm087's Avatar
what size drill bit did you use and for what gauge wire
Old Feb 19, 2004 | 05:13 PM
sadice's Avatar
on my 99 i didn't drill if u look on the drivers side on the firewall there are a bunch of wires going in i took off the wheel cover that is above the wheel and i put the wire through together with the rest of the wires going it kinda hard but i did it and u could to unless uw ant to drill a hole.... it's easier to drill but don't hit anything good luck
Old Feb 19, 2004 | 07:31 PM
Former Vendor
hmmm... i must have missed that hole. i don't know what size bit i used, but it was for an 8 guage wire. now i'm upgrading to a 4, and using a grommet from crutchfield. they list what size hole to match the grommet to match the guage.
Old Feb 20, 2004 | 03:41 AM
sadice's Avatar
it's a pretty big hole heh maybe it's only 97-99 but i think u have a bunch of wires going in as well there is a rubber thing around the wires so the water doesn't get through the firewall so i just took a screwdriver made the hole a little bigger and pushed 4ga wire through......
Old Feb 20, 2004 | 02:36 PM
jtm087's Avatar
BLACKonBLACK98, wouldn't wiring it with the hood release wire involve me taking off my left fender? cause I tried to follow the hood wire fron the front back and it dissappears into a hole in the left fender
Old Feb 20, 2004 | 03:19 PM
carlosr's Avatar
take the splash guard (plastic) off under the fender, above wheel. Its a bunch of star screws holding it in. U may have to jack car up or turn wheel to get at the screws... then there's a hole by battery where wires come out.
Old Feb 23, 2004 | 04:49 PM
jtm087's Avatar
how would I go about putting a seperate battery in my trunk just for the amp, is it expensive or hard to do?
Old Feb 23, 2004 | 05:04 PM
DoNcHoYaX1's Avatar
there are a couple of holes already. there is no need for drilling. look closly they are covered with like a rubber seal just pop the seal and there you have the hole already. Ill take some pics of where I got mine through.
Old Feb 23, 2004 | 05:14 PM
AscendantMax's Avatar
you still need a clean and continuous power source. that battery in the trunk will die out pretty quick if you hook an amp to it. basically, when you hook your power wire to your battery in the engine compartment, the system is getting power from the alternator once the the engine is on. the alternator also keeps the battery constantly charged.
Old Feb 24, 2004 | 03:09 AM
jtm087's Avatar
thanks DoNcHoYaX1 i'll be looking out for those pics, I really don't want to do any drilling if I don't have to
Old Feb 24, 2004 | 05:16 AM
jetblack5spd's Avatar
i have a 96 se and didnt need to drill holes. there was a perfect size hole to the left of the steering colomn in the fire wall. your gonna need someone with a small hand to push the wire through at first. also the rubber grommet that came with the kit fit perfectly in the hole.
Old Feb 24, 2004 | 11:59 AM
jtm087's Avatar
would i have to take anything off to get to this hole, and is there some sort of plug in this hole?
Old Feb 25, 2004 | 09:42 AM
nope no plugs. after you get the wire started through just stick your head underneath the dash and pull the rest of the wire out with your teeth.
Old Feb 25, 2004 | 10:03 AM
DoNcHoYaX1's Avatar
Ok I took the pics but dont know how to post them on the forum. I could email them to you if you want.
Old Feb 25, 2004 | 10:10 AM
DoNcHoYaX1's Avatar
You cant link them from your computer? they have to be hosted?
Old Feb 25, 2004 | 10:18 AM
DoNcHoYaX1's Avatar
Old Feb 25, 2004 | 05:11 PM
jtm087's Avatar
i think I have found this hole but there is a screw there. I tried to push it out but it didn't work.
You are talking about the one with the 3 green hard wires in front of it right?
Old Feb 25, 2004 | 05:48 PM
na man mine had no wires in front of it. i dunno i found mine right away so i guess if you havnt seen yours yet its probably not there, sorry man
Old Feb 25, 2004 | 08:13 PM
s0ber's Avatar
drill drill drill away :\
trsandrew
Oct 25, 2015 02:47 PM
bigfrank
Oct 1, 2015 12:51 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
