sub question
Old Feb 26, 2004 | 07:58 PM
LIMaxin
sub question
how much of a difference do u think this would be? right now i have 2 amp, 1 hooked up to each sub (1 is 1000w the other is 600w) in a bandpass box with 2 12" audiobahn subs. in order to lose some of the weight im switching to 1 12" sub in a ported box made specifically for my sub and im gonna run the 1000w amp on it. seeing how the enclosure is perfect for the sub do u think that it could possibly sound just as good as the 2 in the bandpass? The bandpass box was just some universal box i bought on ebay by the way.
Old Feb 26, 2004 | 08:13 PM
joojoo2915's Avatar
Audiobahn's aren't really known for their sound quality, especially in a pre-fab'd bandpass. If your box is tuned to mid 30's you'll probably lose out a little bit on spl but it will probably sound much better. No way to really know for sure without trying though.
Old Feb 26, 2004 | 10:06 PM
AscendantMax's Avatar
it'll sound nice in a well designed box.
Old Feb 27, 2004 | 05:47 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Just so that Im understanding correctly....you have two subs in a single enclosure and a 1000w amp to one and a 600 to the other??
--Don
Old Feb 27, 2004 | 12:49 PM
LIMaxin
i just installed it and it sounds just about the same as the 2 in the bandpass. the only thing is i get a high pitched "bop" sound on certain notes.
Old Feb 27, 2004 | 08:13 PM
nghtfthlngknvs's Avatar
that "pop" might be your amp/sub going into clipping which can damage them so turn the gain down. you might have too much or too little air space in your enclosure.
Old Feb 28, 2004 | 08:06 AM
jmax
"Bop" could also be port noise.
Bandpass can vary from the most efficient use of amp power and subwoofer money to the worst sounding. Depends on how well they are designed, and sometimes luck.
Old Mar 1, 2004 | 01:19 AM
Tony Fernandes's Avatar
--Don
I was wondering the same thing!
Tony
Old Mar 1, 2004 | 03:32 AM
vqman
sub question?
here's the answer!
don't forget to take the sticker off the back!
-vq
Old Mar 1, 2004 | 01:31 PM
jmax
Tony
When I see info like that in the post I ignore it if it isn't pertinent. In this case he removed one of the amps so the differences between the amps are no longer important.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
