dont know wat went wrong
Old Mar 24, 2004 | 03:39 AM
greekmax2k1's Avatar
i got my 9815cda head unit yesterday hooked everthing up and it works but not sound comonig out of the speakers....only the subs play....i have a factory bose...does anyone know wats wrong...
Old Mar 24, 2004 | 04:15 AM
Pearl96Max's Avatar
I tend to get a bit irritable
How did you wire it up? Through an adaptor? RCA preouts? or just straight wired?
--Don
Old Mar 24, 2004 | 05:22 AM
Scope's Avatar
Im izz sexay
Did you bypass your bose amps. If you didn't then you are screwed. You have to straight wire your HU to the speakers not the amp.
Old Mar 24, 2004 | 05:24 AM
how would i bypass my bose amp...i just got an adapter for the stock wire harness and just connected it to the alpine headunit....
Old Mar 24, 2004 | 07:45 AM
Scope's Avatar
Im izz sexay
hmm...weird. you might have to splice the wires from the speakers and connecting them directly to the wires comming into the amp from the HU. THis will take some time.
Old Mar 24, 2004 | 08:14 AM
Pearl96Max's Avatar
Just put male RCA leads onto the factory speaker wires and plug them into your HU outputs.
--Don
Old Mar 24, 2004 | 06:35 PM
slickrick's Avatar
my friend had the same problem and the internal amp was not on in the h/u, just a thought.
Old Mar 24, 2004 | 08:13 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
Gus i told you with BOSE you have yo buy a High low converter thing...it converts the highoutput signal of the headunit into a lower signal that the BOSE understand....since BOSE runs at different ohms and takes a lower signal
-J
Old Mar 24, 2004 | 09:28 PM
Pearl96Max's Avatar
-J
High/low or line output convetors are used for adding amps not radios. What needs to be I have posted above. The other alternativ is to buy a $50 convertor made for interfacing Bose systems.
--Don
Old Mar 25, 2004 | 04:15 AM
Cubanato's Avatar
--Don
that is what im talking abotu teh BOSE interface...i jsut didnt know the proper name for it
-J
Old Mar 25, 2004 | 05:58 AM
i did all that **** last night and still nothing ****in works...i taking it to a place...i hooked up a normal 4 ohm speakers and it plays so its not the radio.....
Old Mar 25, 2004 | 06:08 AM
Pearl96Max's Avatar
and you Did connect the amp power lead correct?
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
