Viper791XV Alarm Install on 2000 Maxima
Anyone done this before? Where are all the wires I'll be needing to access and how best should I dissassemble the car to get to them? If someone has some step-by-step instructions that would rock. I have the wiring diagram, but some first hand info is always best.
Originally Posted by 02se225
i'm looking at getting the same alarm, how much did you pay and from where
Originally Posted by sanne
sent you a pm man. Also anyone else with more info on this, I can't use the piece of **** search engine because I'm not a donating member, and I can't donate because the site is backed up. What the hell kind of message board doesn't let you search, that's truly pathetic and a waste.
You will need a few more things than just the alarm. You need 2 relays - one for your trunk and the other for your second starter wire. Also your lock wires are in your door so you will have to run 2 wires into the door (lock/unlock.) You will also need the DEI 555U and a copy of your key to keep in the car at all times, since 99's and up have a chip in the key to start the car. I can email you if you want a pdf of all the wires you will need, their color, polarity, and locations for your car.
I ran a separate 10 guage power wire from the battery just for the 791...you will be tapping into A LOT of wires.
Have Fun - The Chad
Have Fun - The Chad
I tend to get a bit irritable
Have Fun - The Chad
Have Fun - The Chad
Lock and Unlock are Not in the door.
Theres no need to run a 10awg to the battery, but I figure that was just Your preference.
-_Don
Originally Posted by Pearl96Max
Actually not all of that is true. Yes a relay for the trunk release, but not for the second ignition. They both need to be cut, but then starter side can be put together into the purple wire.
-_Don
-_Don
The power wire was my preference....mainly for my window modules to get enough power.
I have a 95 and the easiest way to get to the locks was in the door, plus I had to run the wires for window modules anyway. The way I hooked up my remote start was to hook up the second igntion(pink/white) to second accessory. And then use a relay on the skinny purple wire for second starter.
Going into the door was needed on all the 4th gens, as well as 2k2/2k3s. On the 2K and 2K1 it wasnt needed, thus making them some of the easiest Maximas to do. Also unlike the 2K2 and 2K3 you can use just one door trigger lead rather than the 3 that the 2K2/3s have needed to use all of them and diode isolate.
As far as the second ignition you can actually just cut both leads, tie together the starter side and run into the purple lead of the RS. The main wire on the key side would go into the green wire of the RS. Disregard the key side of the second starter. Maybe this will help ya in the future and save some time.
--Don
[QOUTE]As far as the second ignition you can actually just cut both leads, tie together the starter side and run into the purple lead of the RS. The main wire on the key side would go into the green wire of the RS. Disregard the key side of the second starter. Maybe this will help ya in the future and save some time.[/QUOTE]
i use that trick all the time Don! good call
