the best groundings points
Old Mar 23, 2001 | 05:55 AM
Jesse93GXE's Avatar
What are some good grounding points for a sub in the trunk?
Does it matter if some of the cloth trim touches the ground? Probably not since the ground is the chassis and the chassis touches the cloth.. hehe..
A few places I've seen are the trunk latch, the metal edge inside the jack compartment, and those big bolts under the floor mat near the rear.. not sure which to use. It'd be real nice if I didn't have to drill anything.
Recommendations?
Old Mar 23, 2001 | 05:58 AM
Matt93SE's Avatar
STFU n00b!
just figure out where you want your amp and use the closest bolt near it, EXCEPT don't use seat belt bolts. that's fairly self-explanatory.have fun.
Old Mar 23, 2001 | 06:03 AM
Jesse93GXE's Avatar
My amp is mounted on the center of the seatback (in the trunk). Does the bottom of the rear deck make a good enough ground if the paint is scraped away?
I don't see many bolts in my trunk =) except those seatbelts ones, <g>, those were the first I saw.
Old Mar 23, 2001 | 12:56 PM
93 SE's Avatar
i grounded mine to the bolt in rear floor of trunk by armrest
Old Mar 23, 2001 | 05:29 PM
94SUPERMAX's Avatar
Any bolt is good as long as you make sure there is no paint on the metal. The best way to go is to sand down the area to bare metal and then attach the ground to it with a bolt, nice and tight.
Old Mar 31, 2001 | 07:44 AM
Jesse93GXE's Avatar
BTW, just an update. I ended up grounding to the metal rear seat support bar right behind the cover. Was easy to drill in, was already free or grease and paint, nearby and clean looking.
So far I haven't had any problems with noise. That's with both the amp and the inverter grounded, but not the computer.
Old Mar 31, 2001 | 01:41 PM
Cumalot's Avatar
Before I knew anything about cars and/or electronics, I thought when someone ground something, they actually used the ground(cement floor).
Old Apr 15, 2001 | 05:41 PM
SWEETSOUND2001's Avatar
do you think the bolts wont handle the stress in case of an accident? what's the deal? i had 3 1/0 gauge cables mounted to a seat belt bolt.
Old Apr 15, 2001 | 07:51 PM
MaineI30's Avatar
You'd have to drive pretty slowly and make sure you had a long-*** ground wire...
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
