hardwiring a radar detector, noob quest
Old May 25, 2004 | 06:50 AM
bennny
I have a radar detector that i want to hardwire? would this be a smart thing or is there a negative side to it. If i can, where would you suggest doing it and how? thanks, nub electronic question if someone could answer that would be great
Old May 25, 2004 | 04:44 PM
Lytheum's Avatar
its a smart thing to do. i have mine mounted above the rear view mirror. just run the cord across the top of the headliner and then down the a-piller to the fuse box. find a something that is only hot while the car is on and tap it into that fuse. i have a 5th gen and there was a screw inside the fuse box that also makes for a nice ground
Old May 25, 2004 | 07:35 PM
kpr10is's Avatar
i just tapped into the ignition wire from the back of the radio
Old May 29, 2004 | 08:39 AM
Virus's Avatar
I was going to tap into the back of the cig lighter. What power have you all tapped into? How do I take the gear shift panel out to get to the cig lighter. Really explicite instructions would be awesome.
2k2 Auto GLE
Old May 29, 2004 | 09:31 AM
Shinnjee's Avatar
I tapped my 8500 into the blue with white stripe wire (i believe) in the fuse box below the steering wheel, ran the hardwire kit up the driver's side A-Pillar, along the edge of the top windshield but tucked it under the trim and ended above the rear view mirror where my radar is mounted.
Old May 30, 2004 | 08:38 AM
Virus's Avatar
I took the shifter console out and cut all of the electrical tape away from the cig lighter. I then attached the V1's provided splicer into the positive (orange) wire to the cig lighter. I ran the RJ11 through the head liner, down the pillar and under the dash and through the shifter area. It works great with one exception. The tape/velcro provided doesn't stick very well. I will have to buy some doublesided 3M tape and see if it works.
James92SE
142
Jan 2, 2024 09:23 AM
AaronL
Nov 15, 2020 11:52 AM
JRod28
Feb 4, 2016 11:07 AM
sake1bs
Sep 19, 2015 09:32 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
