hardest part of installation
Old May 31, 2004 | 04:01 PM
sk24iam's Avatar
What do you think is the hardest part of installing a basic system. I tihnk it is hiding all the wires once everything is done.
Old May 31, 2004 | 04:17 PM
ShRapNeR's Avatar
actually getting to the RCA jacks on the back of the HU
Old May 31, 2004 | 04:22 PM
slickrick's Avatar
running new wires 4 interior speakers
Old May 31, 2004 | 04:31 PM
1996blackmax's Avatar
With the Maxima, dealing with the little squeaks here and there after panels have been removed .
Old May 31, 2004 | 05:31 PM
Devchuck2g4's Avatar
speaking of panel, how do you remove the front speakers? Anyone have a write up on this??
Old May 31, 2004 | 06:12 PM
Kojiro_FtT's Avatar
The hardest thing is running new speaker wires to the doors. Everything else is easy, as long as you have the right resources (such as the org).
Old May 31, 2004 | 07:21 PM
DerekJ212's Avatar
Definitely getting new speaker wire through the doors. Then a distant second is getting the power wire through the firewall.
Derek
Old May 31, 2004 | 07:24 PM
djfrestyl's Avatar
Suspension Yoda
after building a custom trunk....getting it INTO the trunk
doh!
Old May 31, 2004 | 07:29 PM
SEmy2K2go's Avatar
Go BUCKS!!!
doh!
That and coming up with a design to begin with.
Old May 31, 2004 | 07:59 PM
AscendantMax's Avatar
for me...it used to be removing the rear seat to get to my rear speakers. that seat was a b*tch to remove the first few times.
Old Jun 1, 2004 | 05:58 AM
MacAlert's Avatar
After seeing Don install my system yesterday, I would say its running the wiring and figuring out the stupid whine!!
Old Jun 1, 2004 | 12:13 PM
Batxel's Avatar
blah
New wiring through the front doors!!!!(it took me at least an hour) I had to run seperate wires for the tweets and the midrange. I didn't want to even attempt putting crossovers in the doors. It took me more time to run the wires through the door than take the door panels off.
Old Jun 1, 2004 | 04:56 PM
nismos14's Avatar
§è~® f®ÈÄk
how to mount the sub while keeping the spare usable, and keeping my amp mounted against the back seat (soundstream 4 channel 18 inches wide, can't fit anywhere else!!) hoping the velcro does the job
Old Jun 1, 2004 | 06:42 PM
nostrixoxide's Avatar
Keeping the sunroof, front & rear windshield from popping out when volume is high, doors are closed & the widows are rolled up?
No, seriously, I would have to say changing out the rear deck speakers, door panels were a breeze. I guess the old wire hanger trick still works for me...
Old Jun 1, 2004 | 06:47 PM
JPMax's Avatar
What's next!?..
Hmm..
1st running new speaker wires and getting to the rear speakers a close 2nd.
Old Jun 1, 2004 | 10:49 PM
Maxima Dan's Avatar
I think the hardest part is ever being satisfied enough to call it complete. Every time I tell mysely I'm not going to spend another dime on my system...
Old Jun 1, 2004 | 10:54 PM
slickrick's Avatar
i agree 100%! im going from 2 10's to 2 12's and i still dont think ill ever be done. its an expensive hobby for me.
Old Jun 2, 2004 | 07:58 AM
LeX's Avatar
LeX
Nissan by Nature
i dunno the hardest part was that it took me so much time to do it, but the actual job wasn't hard
Old Jun 2, 2004 | 04:35 PM
maxceleration's Avatar
Why would you run speakers all the way to your door?
All I did was run the speaker wires from the amp to my HU.
My HU is connected to all 4 speakers through the wiring harness. All I did was disconnect the wires from the harness that connected to the HU, and connect the "front speaker wires" from the amp to them. Much more simpler than going through the doors. Now if you wanted to upgrade to a significantly higher guage wire, then this should be it.
And I just wired inside of my trunk into my rear speakers from the amp. That was probabaly the easiest part.
Granted, the first time I took out the rear seat was a B!tch!
SmokinMax02
18
Sep 11, 2015 12:25 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
