Wiring Diagram for neons/rca/amp power wire
Old Jun 2, 2004 | 03:14 PM
onecrazymaxnut's Avatar
Does anyone have a write up or wiring diagram of how to wire power for neons under the dash n seats..run rcas from headunit, run power for amps as well as all the speaker wire for inside speakers w/out crossing power/signal wires in order to avoid engine noise ? all in all im gonan b running a lottaa power wires/speaker wires/ etc i wnat to avoid engine noise if i can---if someone has wired all this already i can avoid using my precious brain cells from trying to think of how to do this
Old Jun 2, 2004 | 04:26 PM
MIXXMAX's Avatar
Power the neons on any positive power source (such as parking light circuit. Also, I would recommend installing low amp in-line fuses to avoid any shorts. For stereo, run power wires on side of car on same side as battery. Run speaker wires and RCA's on opposite side. Use high quality shielded RCA's to avoid any noise from speaker wires. For ground wires, use short distances and ground to bare metal. I hope this gets you started.
Old Jun 2, 2004 | 04:35 PM
OpTi's Avatar
yeah just run power and speaker wires on different sides of the car and you should be fine.
The Frye
Sep 2, 2021 11:03 AM
kjlouis
Sep 14, 2015 11:22 AM
popdedop
Sep 11, 2015 11:17 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
