alpine type r
Old Jun 3, 2004 | 03:40 AM
OpTi's Avatar
alpine type r
My current setup is a jbl 600.1 and a 12 inch alpine type r in a sealed box. It's probably getting about 500 watts. Would it sounds better or be louder if i add another 12 inch sub into a sealed box? So each sub would be getting 300 watts rms. Thanks.
Old Jun 3, 2004 | 09:27 AM
Kojiro_FtT's Avatar
You know the answer to this one now
The real question is do you want to spend the extra money on another sub and give up the trunk space? I stayed with a single sub for trunk space.
Old Jun 3, 2004 | 10:22 AM
slickrick's Avatar
my buddy has 2 12" type r's on a jbl 600.1 in his crappy hyundai and they can be loud enough to make you get out of the car. id run 2 of the type r's anyway because the rms is 300... i know they can take more but if you dont mind adding some weight and losing some space id try it out. also he had 1 12" type r on the jbl and he blew it... and when he added the 2nd it was def. alot louder.
Old Jun 3, 2004 | 02:24 PM
OpTi's Avatar
Yup, Thanks Kojiro.
Slickrick, that's exactly where i'm at right now. I got another type r today. It should be arriving tomorrow. Now i'm gonna need to build another sealed box. The wiring is going to be tricky.
Old Jun 3, 2004 | 02:41 PM
slickrick's Avatar
do you have dual 2 or dual 4 subs?
Old Jun 3, 2004 | 05:15 PM
OpTi's Avatar
it's dual 4. i figured the wiring out. now i just need to build a box.
Old Jun 3, 2004 | 06:07 PM
slickrick's Avatar
so wire it at 1 ohm. about 1 cube per sub is good for the type r's.
Old Jun 3, 2004 | 06:16 PM
OpTi's Avatar
yeah, i'm pretty sure that the jbl 600.1 is 1 ohm stable. am i correct?
Old Jun 3, 2004 | 06:19 PM
slickrick's Avatar
yes it is.
Old Jun 4, 2004 | 09:39 AM
OpTi's Avatar
I have another question. So I wire both subs down to 2 ohms. Do i just then connect each to the amp like I would normally do? Even though it's a mono amp it has 2 pair of speaker outputs. If it just connect - to - and + to + on both subs then will the amp see a 1 ohm load?
Old Jun 4, 2004 | 09:42 AM
slickrick's Avatar
the amp internally bridges them so just like you said is fine. with 2 DVC 4 ohm subs you get a 4 or 1 ohm load just to verify.
http://www.jlaudio.com/tutorials/wir...ex.html#2dvcsp
Old Jun 4, 2004 | 09:44 AM
OpTi's Avatar
nice quick response..thanks
Old Jun 4, 2004 | 09:54 AM
slickrick's Avatar
what size box are you making?
Old Jun 4, 2004 | 09:58 AM
OpTi's Avatar
1.25 cubic feet each..sealed
Old Jun 4, 2004 | 10:00 AM
slickrick's Avatar
nice. you will like it alot better than the one sub.
Old Jun 4, 2004 | 10:03 AM
Slow Moe's Avatar
Is there any way to wire 2 DVC 4 ohm subs into a 2 ohm load?
Old Jun 4, 2004 | 10:07 AM
slickrick's Avatar
not that i or jl audio knows... 1 sub can be wired into a 2 ohm load though.
Old Jun 4, 2004 | 12:55 PM
OpTi's Avatar
i'm putting them together now. one sub is different from another. on one the alpine words are white and the other is black. the gray cone on it is also different. one is a little darker than the other. is it just a newer model?
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
TheMafia
Sep 4, 2015 08:26 AM
