need some tuning help (any alpine amp experience?)
Old Jun 4, 2004 | 12:18 PM
sk24iam's Avatar
I'm wokring on setting up my alpine mrd501 to me edaudio 12O. This amp is very complicated so any help would be appreciative.
For adjusting the imput level it says in the book: .1-2.0V/0.5-8V On the amp the settings range from 0-24db. How ouwld I go about adjsuting that?
For the gain factor level, the adjustments can be0db/+6db/+9db
What should the lowpass filter slope be set at? the two options are 12/24db
Do I need to mess with parametric equalizer mode, bass compensation mode, time correction mode, or amplifier id mode?
Old Jun 5, 2004 | 06:46 PM
nismos14's Avatar
§è~® f®ÈÄk
if u want a sharp cutoff on the bass 24 db, if u want it to blend a little bit better 12 db
the rest is really up to you its all something u should play by EAR literally listen to it and see what sounds better to you
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Socalstillen
Sep 26, 2015 12:01 PM
