5th Gen Headrest, Power, and X-Box Questions
Question 1:
In the stock 2002 SE headrests, what's the largest screen you can put in? I'm looking at Kenwood's line for the headrest monitors, as the rest of my audio system is also Kenwood. I'm willing to look at other models like the Microvision, etc. What is the maximum size for the headrest, and what do you recommend I should put there?
Question 2:
I'm gonna be running a X-Box in the car. Does anyone know what wattage power invertor I would need to run it without problems (links are welcomed)?
Question 3:
I was looking for a spot to mount the X-Box. The unit fits nicely under the passenger's seat without being dismantled, but I would like more opinions on where to mount it. I don't want to put it in the glove box, and the trunk isn't really an option due to my sub box, so where should I put it?
Question 2:
Question 3:
Question 1:
I don’t think there is one definite answer to this question. Just because each kind of monitor comes with diff styles of headrest shrouds, and depending on how large that shroud is, it will determine what size monitor can fit. I have seen 7" screens with small shrouds, and I have seen 5.6" screens with large shrouds all fit in 2k2 headrests. So that is what it really comes down to.
Question 2:
I would say that a 150-300 watt inverter should be enough for you. Especially if you are going to just run the XBOX.
Question 3:
I have my PSII under the driver seat in my 2k2 and it fits there perfectly, plus you have easy access to put in the games. I know that my PSII is smaller then the XBOX but that is probably the easiest and most convenient spot to mount it.
Hope this helps.. PZ
Question 2:
Question 3:
1) The bigger the better, you cant find almost anything you have on your car on any other maxima, so why not get some custom headrests
2) Ive heard they work fine on like a 150 watt, we sell 180 watt ones at circuit city for pretty cheap
3) Its so big that u have not many other options besides under either seat
Matt93SE
Apr 8, 2018 09:23 AM
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
