Battery terminal ? and fuse block ?
I am looking at buying a new aftermarket positive battery terminal. I need it to hold a 4 gauge wire. Any sugestions on which kind to get? I also have a fuse block that has a voltmeter on it but it isn't working. Is there something I have to do to it to make it work? Thanks
Dan
Dan
lol the battery terminals we sold at circuit city were nickel, the material theyre made out of is really the only thing to worry about.
i dont have a clue how to troubleshoot a voltmeter display of a fuse block, sorry lol
http://www.knukonceptz.com/productMa...ry%20Terminals
About the Fuse Block, not really sure either, but a new one is not that expensive. If you want something a little more trick, check this out...
http://www.icixsound.com/vb/showthread.php?t=448
Ok, i'm not sure if this will help you, but i used marine terminals with wing nuts and soldered cable lugs on the ends of my cables..you can buy the lugs at any welding store or wal-mart i think..to solder them on you NEED a soldering TORCH, not a pencil soldering iron or even a soldering gun..you can crimp them, but i prefer soldering.
bigfrank
10-01-2015 12:51 PM
