I think I have a BLOWN/BROKEN DIAMOND M6???
Old Jun 27, 2004 | 05:54 PM
Igor911's Avatar
Well I built a new enclosure and wanted my sub inverted this time. After everything was hooked up I noticed a WEIRD baffled sound comming from the sub.
FYI- Enclosure is 100% sealed perfectly and even has rubberized lining inside.
Here is a video of the noise: Video
Does anyone know what is going on with my sub??? I'm really ****ed at this issue.
Old Jun 27, 2004 | 06:14 PM
OpTi's Avatar
so it just makes that noise with no bass?
Old Jun 27, 2004 | 06:16 PM
OpTi's Avatar
also, did you invert the wires when you inverted the sub?
Old Jun 27, 2004 | 06:21 PM
Igor911's Avatar
invert the wires, what are u talking about!?
Old Jun 27, 2004 | 06:27 PM
friendhasmax's Avatar
dude you are out of control.
invert the wires? do you mean reverse the polarity? that has nothing to do with noise.
the surround is either hitting the MDF or there is an air leak around the mounting location.
Old Jun 27, 2004 | 07:12 PM
OpTi's Avatar
Inverse the polarity, that's what i meant. I've never inverted a sub before but i know that you have to reverse the polarity.
Old Jun 27, 2004 | 07:51 PM
MacAlert's Avatar
The sub looks like it is being sucked in instead of pushed out. Reverse the wires and see if that works.
Old Jun 27, 2004 | 08:20 PM
HitManSE's Avatar
Very strange indeed. Sounds like its hitting against something IMO.
Old Jun 28, 2004 | 02:03 AM
vqman
EDIT:
is this the first time you've installed this sub? or is it the same sub now having problems, if it's a brand new install, I have your answer...
Take the sub back out of the enclosure, on the back of the sub magnet is a clear sticket that says "remove before installing"
remove this sticker, and let the air flow through the hole it was covering up.
this should clear things up.
if the sub was working before, I have no clue
BTW, what are you powering them with?
-vq
Old Jun 28, 2004 | 02:12 AM
thekenone's Avatar
i also agree that it looks like its sucking in instead of pusshing out. that will create that sound. but check to make sure that the hole you cut is big enough. the stencil for the hole that came with the speakers is gonna be too smallyou need the hole to be about 1/4 inch away from the rubber so it has room to flex and bounce
Old Jun 28, 2004 | 04:52 AM
Igor911's Avatar
I will check on the reversing wires....
As for the sound...I think it may be hitting the mdf, I will check it out asap.
and no this sub is not new, I had used it in a different enclosure.
Thanks for the tips guys
Old Jun 28, 2004 | 01:23 PM
vqman
what size is that M6?
I had two M6 10's, and they were to heavy for my '03
the rear end was squatting, I had to take them out and put in one CM3 10'
-vq
griffins98max
Aug 30, 2015 10:23 PM
jdonavich
May 8, 2004 06:09 PM
sickmen
46
Oct 11, 2001 08:31 AM
Wreck-Diver
Jul 16, 2001 08:56 PM
barrett58
Jan 22, 2001 12:05 PM
