amp and sub question
Old Aug 6, 2004 | 07:43 AM
blaze0ne
i wanna put a sub and an amp into my max. i currently have the bose system and i am not getting a new headunit or speakers.
i already have the amp that i took out of my old car; its the Power Acoustik Area 51 800x4 and it was hooked up to 4 infinity kappas.
what i wanna do is add a kicker solobaric S12L7.
the amp:
85 x 4 at 4 ohm RMS, 105 x 4 at 2 ohm RMS, 210 x 2 at mono RMS, 800 bridged
THD at Rated Power: 0.02% @ 4 ohm
S/N Ratio*: >97 at rated power
Frequency Response: 10 Hz-30 KHz
Variable Low and High Pass filters
Tri-Mode Capable
18 dB boost at 40 Hz
Dimensions: 16.5" D x 2.5"H
the sub:
http://www.kicker.com/ShowPage.cfm?f...enu=SUBWOOFERS
750 rms at 4ohm
my main concern is if this amp is appropriate to pump the sub
also any other input on the sub or amp is appreciated
Old Aug 6, 2004 | 08:17 AM
Pearl96Max's Avatar
I tend to get a bit irritable
being that its a 4 channel amp, you would still have 2 channel left unused. Also would depend on what impedance your sub is whether the amp can be used atll. DO you know if its a D2 or D4?
--Don
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
