Pac Swi-x
Old Sep 3, 2004 | 06:37 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Pac Swi-x
Does anyone have a write-up for this product? Would like to install it.
Old Sep 3, 2004 | 07:18 PM
irish44j's Avatar
retired moderator
what is it?
Old Sep 3, 2004 | 08:42 PM
2k3TitaniumSe's Avatar
Steering wheel control?
Old Sep 3, 2004 | 08:43 PM
This is what i found!
http://www.autotoys.com/x/catalog/UN...WIX_p_597.html
Old Sep 3, 2004 | 09:26 PM
steaLthyMax's Avatar
its a steering wheel control adapter so you can use the stock steering wheel controls with an aftermarket headunit. i bought mine two months ago and its still waiting to be installed...the instructions that come with it suck and i dont trust myself with soldering the resistors
Old Sep 4, 2004 | 12:36 AM
slickrick's Avatar
theres no need to solder resistors. theres a write up in the faq's up top.
Old Sep 4, 2004 | 08:41 AM
Epacy's Avatar
Where are you talking about?
Old Sep 4, 2004 | 10:23 AM
slickrick's Avatar
http://forums.maxima.org/showthread.php?t=291114
Old Sep 4, 2004 | 07:41 PM
sachmo12345
i cant give you any help on installing but i know it isnt very hard because my friend just did it but you need to figure out a good mounting point for the transmitter that send the signal to the head unit
Old Sep 7, 2004 | 05:49 PM
WildmanAL's Avatar
Here is where I installed my LED
You have to install resistors online with the module so you get the the right current. Soldering is not needed at all..... just crimp them together with some connectors.
The install isn't that hard, but I had some trouble programming it. Dad had to come over and help for a minute because it involves holding down buttons on the module and on your steering wheel controls.
I'm pretty sure I just went by the instructions that came with the devise, but I may of used some info from the org aswell. Do a search and check the faqs.
Old Nov 22, 2004 | 11:11 PM
LithiuMax
AL.. where did you mount the PAC unit itself? Behind the headunit or...?
Old Nov 22, 2004 | 11:27 PM
WildmanAL's Avatar
Yeah man I just stuck it behind the HU.
Old Nov 22, 2004 | 11:30 PM
LithiuMax
OK.. so it's pretty much the resistors attach to the white wire, and then the other ends of the resisitors attach to the wires that were attached to the old headunit, right? There's a lof of room for the PAC unit back there? Did you glue it in so it doesn't move around?
Old Nov 23, 2004 | 05:35 AM
WildmanAL's Avatar
I think that's all I used was one resister with the white wire, but I don't remember what I hooked up to what. As for the unit...... it's so light it won't move around. There are too many wires/RCA wires holding it still back there.
Old Nov 23, 2004 | 09:18 PM
OneToughMax's Avatar
here's the link to the instructions right from the pac website: http://www.pac-audio.com/swixprogramming/default.htm
9aj9
Apr 5, 2020 12:11 AM
ivorton23
Sep 28, 2015 09:08 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
jdmatl
Feb 28, 2002 05:45 PM
