Amp kits...
Amp kits...
$24.64 - 1100-Watt Car Amp Wiring Kit, KPA4X2:
http://www.walmart.com/catalog/produ...uct_id=1863080
Anyone use this? Seems like a good deal.
Originally Posted by generation3
Its from walmart how good can it be?
Originally Posted by Fosgate Fan
oxygen free copper is oxygen free copper. my 12 gauge speaker wires i'm using are from walmart, and everything sounds fine.
I was having fun with someone the other day comparing Lightning Audio, Scosche, Metra and Stinger...There is quite a visable difference between them.
Typically you would want to find a high strand count, very thin, Very tightly wound. This is the prime reason you dont see competitors using welding cable. Although it is a Much cheaper alternative the thread count is extremely low, and strands are extremely thick, making it almost impossible for tight bends as well.
--Don
Don is right (like always) I was running a kit like this for years with my rockford amp after upgrading to a higher end amp I had engine wine I could not get rid of after trying every thing in the book to fix this I changed to stinger helix rca cables and BAM no mo wine .good luck
Originally Posted by Pearl96Max
Actually not entirely true. Although for the typical basic system it doesnt really matter much. Other things to take into consideration would be : Strand count, Thickness of strands, How tightly wound it is,etc..
--Don
--Don
i stand corrected. seems to me that some wiring kit's price are elevated just because it has some big company name stamped on them.
--Don
The power wire and remote and ground wire will all be fine in that kit. Just to let you know the 4g wire will make it into the back seat. The RCAs are fine for subs, not for highs, **** load of engine whine. If you use that kit, you will either need to extend the power wire like i did...which was a pain twisting each strand together and covering it all in solder, or just use the splitter block type deal that comes with the kit, note you will only end up with 8g wire if you do this, which is fine for some people, but not for me when i amped all my highs and put more power to my subs.
popdedop
Sep 11, 2015 11:17 AM
