Voltage
Old Sep 20, 2004 | 01:00 PM
sachmo12345
Voltage
The amp i am getting says it is 500 watts RMS at 12.5 and 800 watts RMS at 14.4 is there a way to change voltages i have a 95 Maxima im not saying i know what my voltage is but how does it change
Old Sep 20, 2004 | 03:24 PM
Micah95GLE's Avatar
The voltage changes when you turn your car on and off. Off = ~12.5V; On = ~14.5V. Amps with unregulated power supplies will produce more wattage with more input voltage.
Old Sep 20, 2004 | 03:55 PM
sachmo12345
thank you soo much
Old Sep 20, 2004 | 09:37 PM
friendhasmax's Avatar
voltage drops when there is more current demanded than there is available.
Old Sep 20, 2004 | 09:46 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Actually just by turning the car on would not produce 14.5V. Depends what else is on, like the post above states. But more importantly you will only get that at higher RPMs. At idle expect maybe mid-high13 range.
--Don
Old Sep 20, 2004 | 09:55 PM
--Don
grrrrrrrrrrrrrrrrrr
AaronL
Nov 15, 2020 11:52 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
