amp stopped working
Old Sep 22, 2004 | 07:33 PM
anton9881's Avatar
amp stopped working
today as i was driving i noticed that my subs stopped working. i popped my trunk and investigated. i narrowed the problem down to the amp because my cap is getting power and so is the neon in my box. Plus my amp has built in gauges in the front and they stopped working. i checked the amp fuse and it is not blown. is there any way i can check the amp to see if its blown? the amp is made by volfenhag. its a 400.2 and its pushing 2 400rms audiobahn subs. i am 16 years old and i do not have access to many electrical measuring devices. thanks for your help.
Old Sep 22, 2004 | 08:32 PM
aspec0002's Avatar
get it bench tested at a audio shop, any decent shop has a tester. and volfenhag is not exactly great product, more then likely its done. try to save your money for something more reputable, youll save money in the end by buying better product.
Old Sep 22, 2004 | 09:20 PM
-Red-'s Avatar
Try and rule out the remote wire; run a wire from your + to remote (on your amp) to see whether the amp will power on or not. If it does, then for some reason there's a problem with your remote wire/head unit.......
Its a longshot, but worth a try.
Old Sep 23, 2004 | 12:48 PM
KCMaxima98's Avatar
How do you have the subs hooked up? I mean what ohm load is your amp seeing? Next, where is the amp mounted? Is it crammed between the seat and box or somewhere where it doesn't have room to breathe? The amp may have gotten hot and just shut down until it cooled. It may turn on next time you turn on the stereo.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
