Driver side leds
Old Apr 9, 2001 | 05:42 PM
BluLite's Avatar
Does anyone know what kind of leds are in the driver side door? i know they have 4 pins but cant find them online.. thanks!
Old Apr 11, 2001 | 10:27 PM
GarthG's Avatar
Where do you mean? in the window switches or in the courtesy lamp?
Old Apr 12, 2001 | 11:22 AM
BluLite's Avatar
the window switches on the driver side (door lock, and 4 window switches)
Old Apr 12, 2001 | 12:19 PM
GarthG's Avatar
If you have a 95-99, then click on the link in my sig and it will tell you the part number at Radio Shack for blue, but they are just 5V LEDs in any color you want. . . If you have a 2K+, then I wouldn't recommend trying this as the only person I know who has tried this has fried a relay because somehow they are different. 97+ can't have the rears switched out to coodinate at this point in time, although a few people are working on it.
Old Apr 12, 2001 | 01:30 PM
clee130's Avatar
You used a 5V? How much brighter is that than the 3.7V? I used a 3.7 in my security LED and although it's bright, I wonder if I can put a 5V in there.
Old Apr 12, 2001 | 01:56 PM
GarthG's Avatar
I used 5 V just to be safe. . . I ran the stock voltage through a voltmeter and it was around the 3.7 range, so I didn't want to push it, the 5V can also take more current. These are what my LEDs in the window switches currently look like:
They are bright enough, but I would expect that they aren;t as bright as a 3.7 volt LED would be if only 3.7 volts are going through the LED. BTW the white ones are 3.7 volts in the pic about as they don't make 5V white ones yet.
Old Apr 12, 2001 | 04:31 PM
BluLite's Avatar
i have a 2k1... the leds are different than the ones you have.. the ones in my car have 4 leads.. and they are surface mount..
boomerbrian
Oct 31, 2018 10:25 AM
asianstyle
Sep 10, 2015 11:30 AM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
