1 inch thick MDF
Old Sep 23, 2004 | 12:46 PM
sachmo12345
1 inch thick MDF
I can not find this wood anywhere ive gone to industrial suppliers etc anyone know where i can get this my sub box guide says to use this wood with my sub any alternative or ideas to get around this problem
Old Sep 23, 2004 | 12:52 PM
Micah95GLE's Avatar
Yeah- you can glue & screw 2 sheets of 1/2" MDF together. That is a common practice. If you want to be hardcore, you can sandwich a layer of sound damping material (Dynamat-type stuff) between the MDF layers. That's what I did for the mids in my doors.
Old Sep 23, 2004 | 12:59 PM
Maxima Dan's Avatar
http://www.emersonhardwood.com/cchw/...=9117765456014
Kinda far from OH, though.
Can you find 3/4 MDF? Home Depot or Lowes almost always has it. It will probably be enough. Normally you would only need the thicker material for the baffle, andyway. And if that's the case you can always double up the 3/4 to get a 1.5 thick piece. Just remember to glue the pieces together.
Old Sep 23, 2004 | 01:08 PM
Micah95GLE's Avatar
Yeah, you can always use 3/4" MDF for the sides, top, and bottom, and use internal bracing if the box is big. Then double the MDF for the baffle. I wouldn't be too concerned with using 1" MDF if it wasn't readily available.
Just make sure that you adjust your measurements if you use 3/4".
Old Sep 23, 2004 | 01:09 PM
sachmo12345
thats what i need to use it for only the piece of wood that the sub is screwed into will be 1" thick but i guess i wll just glue to piece together what kind of glue should i use
Old Sep 23, 2004 | 01:18 PM
Maxima Dan's Avatar
What I use is just normal wood glue...DO NOT USE LIQUID NAILS, it's way too thick for this. You need to spread it around so that it covers the whole board and then set something really heavy on top of the boards. I use my stock rims and tires for this Let it sit for 24 Hrs and then cut to size.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Garrettz459
Sep 28, 2015 02:50 PM
Luigi623
Sep 21, 2015 01:42 PM
jcvgn
Sep 13, 2015 11:42 AM
Maxboy23
Sep 4, 2015 06:04 PM
