Need help to install a sub + amp to 00' SE w/Bose system
Hi,
I need some help on the aftermarket installation of the amp.
I ran the power wire to the amp from the battery, but now, I need to connect the sound wires...
Do I have to connect them before the Bose amp or after it?
I tried to connect the amp instead of the big rear speaker, but it sounds too weak. (I am putting in 2x10" 500W each subs and a 1000W amp).
Any suggestions how to connect it?
Thanks in advance,
Ilya
Thanks in advance,
Ilya
Thanks guys. I actually found a way, how to avoid the hi/low adapter I was looking at the rear sub's wiring, and found out that it has its own 100W amp (just for the sub). I figured that the wires coming in there are preamp inputs. So I hooked up the amp directly to them, avoiding the high/low. The bass is pumping out now ))
MaximaDrvr
08-19-2015 08:20 PM
