Hey help with sound system
Old Oct 14, 2004 | 12:35 PM
Assassinroon's Avatar
Diamond M6 10" subs for 125 is that a good price and good quality subs ?
Pioneer GM-4000F amp 4 X 70w @4ohms $125
that good amp to run them on ?
Hit me up with suggestions also anyone got a right up on how to install tweeters in a maxima i got the apline type s ones front deck
Old Oct 14, 2004 | 01:02 PM
2 Da Max's Avatar
diamonds are good quality subs, i dont know about that amp
Old Oct 14, 2004 | 02:49 PM
KCMaxima98's Avatar
That amp is only 35 watts rms x 4. Not enough power for those speakers. Not by a long shot. Bridged, it will only be 70 watts rms x 2 at the most. Pay attention to RMS ratings, not maximum wattage.
Old Oct 15, 2004 | 12:06 PM
so the subs are good at that price? Can anyone suggest a good amp for me plz
Old Oct 15, 2004 | 12:33 PM
Wish-it-was-AWD's Avatar
Find an old kicker zr 360 or 600 (overkill)...maybe even a 240 could satisfy your needs, and they're cheap as hell on e-bay (when someone sells one).
Old Oct 16, 2004 | 09:35 AM
that deal isnt falling thru guys i dunno what happened. Anyone suggest a good set of 10 inch subs and a amp to run them on. Also anyone know why if i put my volume high my speakers get all staticy. I got type s comps in the front and coaxials in the back
Old Oct 16, 2004 | 11:38 AM
problem...too much distortion at high volumes due to inadequate power (not enough headroom), or bad wiring, or bad H/U S/N ratio or THD...get one JL 10w7, and a JL 500/1...it will absolutely slam....have excellent SQ, take up less space than most two 10" setups, it will last longer than most other subs, and cost you under a grand for the whole sh-bang....hell....I'll sell you three 10w6s with a Kicker ZR 600 for $1,000....I used to be an installer...gain has been set below 1/4 for its whole life and it will be loud enough...if properly installed, to drive you out of your car...and the sound....cleaner than a virgin's panties...
Old Oct 16, 2004 | 12:08 PM
Longboarderphil
JL Subs are not good for SQ are you out of your mind...image dynamics, is the best bang for ur buck, hook up a good amp and a good set of speakers in kick panels and u will have amazing sq, i would suggest a set of DLS components in the front. nothing in the rear. one 10 or 1 12 inch ID max sub and zapco amps to run everything
Old Oct 16, 2004 | 03:30 PM
Longboarder...You have illustrated to me how little you know about SQ by suggesting Zapco amps, especially over the Kicker zr series or XS...nothing need be said in defense of JL w6's or w7's SQ. If you've heard these and they sounded poorly they were not set up properly. I spent a long time on a longboard, but I've spent much more installing high end audio systems.
Old Oct 17, 2004 | 01:16 AM
Kikcaffine's Avatar
The diamond i have is pretty clear sounding at high volumes, but i just found out yesterday its really boomy in the back seat when i was letting my friend drive.
Old Oct 17, 2004 | 11:26 AM
Ladzio's Avatar
You've got distortion when you pump up the volume because your receiver deck is far too weak to power your Type S. It gives out 18-22 W RMS per channel at best, while your Type S are 50W RMS. You will need 4-channel amp and more sound deadener to get good clean sound, and a sub of course.
If you gonna install 2 amps, you WILL want a capacitor (sp?), in order not kill your battery and laternator too soon... they are under 100 bucks on eBay.
P.S. I did some research, Rooney...!
Old Oct 21, 2004 | 11:16 AM
haha nice vlad hmm well i guess its time to buy a amp any 4 channel ones up for grab?
Old Oct 21, 2004 | 11:22 AM
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5726892013
hey this a good amp for the 4 speakers im trying to give wattage to
Old Oct 21, 2004 | 04:36 PM
Ladzio's Avatar
Nah, that's a 2 channel and too strong. Look for 4 channel, A used amp from a reputable company should fit your budget.
Old Oct 22, 2004 | 08:19 PM
hey what 4 channel amp should i get is there any cheap ones ya have in mind?
Old Oct 22, 2004 | 08:23 PM
Ladzio's Avatar
Don't know, I'm looking too now. Maybe some used kenwood or alpine, or clarion would do as well.
Old Oct 23, 2004 | 12:33 PM
joebangaa's Avatar
didnt everyon flame longboarderphil in a diff thread a while ago concering jl's and id's and blah blah
Old Oct 23, 2004 | 02:36 PM
Ladzio's Avatar
What's your point?
Old Oct 23, 2004 | 03:08 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Distortion comes in not soley because of lack of power from a HU, but the distortion level itself is quite a bit higher on ANY HU over an aftermarket amp. Running two amps Does Not mean that you will need a cap, in most cases theyre useless anyway. They are a simple bandaid for a car lacking elsewhere. BTW I run 4 amps...I have no cap.
--Don
Old Oct 23, 2004 | 07:49 PM
Ladzio's Avatar
I take my words back about the capacitor...
Hey Don, are you running power wire from the battery or from alternator?
Old Oct 25, 2004 | 12:01 PM
bump anyone know a good amp 4 chanel or sellin one?
Old Oct 29, 2004 | 10:43 AM
Kicker ZX 460...for sale on ebay right now...underrated power, clean, flexible, cheap...
Old Oct 29, 2004 | 03:29 PM
MannyNJ2k2max's Avatar
ZR360....its in my hall of fame, literally bulletfroof.....current-thirsty sucker though
Old Nov 1, 2004 | 10:51 AM
for once we agree...
the entire zr series has impressed me...but with adequate wiring, H/O alternator, and second battery, it is ungodly strong, cleaner than any digital amp and as you said bullletproof....
Maxima.KsA
May 15, 2020 04:14 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
