What speakers for front doors of 4th Gen?
Old Oct 23, 2004 | 03:50 PM
Black Maxima
Hi, what speakers fit in the two front doors of a 1996 Maxima? I tried a Pioneer 6 1/2, but it didn't fit when used with the stock plastic mount piece. The door panel hit the top of the speaker. How did you guys mount your front door speakers in your 4th gens?
AARON
Old Oct 23, 2004 | 06:55 PM
oceancrest67's Avatar
I am having the exact same issue. 97 Nissan Maxima...and I am in the middle of a system upgrade: hu, plus all 4 speakers. I have new pioneer 6.5 inch speakers and I see that it may be possible to mount them on the existing speaker mount using the outside metal tabs...the holes do not line up exactly. On the speaker mount there are two plastic line up prongs which may have to be filed down for some kind of fit.
The other option I am telling myself is to purchase some kind of speaker harness that compensates for the different holes etc...this would then get attached to the speaker mount and the the speaker itself.
There has to be some sort of after market speaker mount or bracket that will fit the existing mount and line up with the speaker holes.
Jeez, if is not one thing...then it is another.
Anyone have any tips?
Old Oct 23, 2004 | 07:14 PM
Black Maxima
Yeah, you typed out everything I was to lazy to type.
What I did was mount my 6 1/2 that I took from the back deck onto the plastic mount. I used the screws that came with the speaker. I screwed them right into the factory screw holes in the plastic. I didn't get the screws in as good as I would like, but I was good enough. Then, I put the door panel back on and the speaker grill on the panel was hitting the speaker - no good. So I don't know what to do and what speakers to get.
I hope all that made sense.
And after I put everything back together I noticed when I power lock my doors, they lock and quickly unlock. That's when the key is in the ignition. When I have the ignition turned off the locks work fine.
Oh yeah, I filed down those **** with a Dremel.
Old Oct 23, 2004 | 09:49 PM
YellowOne's Avatar
had pioneer 3 ways in my car didn't fit right, so i upgraded to infinity 2 ways and they sound 10x better and fit plush.
Old Oct 24, 2004 | 07:49 AM
Black Maxima
Thanks for the reply. Did you use the stock plastic mount?
Old Oct 24, 2004 | 09:12 AM
I just ran back to Best Buy and exchanged the 6.5 pioneers with the 6.75 4way pioneers...the holes line up perfectly with the slightly larger speaker. I have yet to attach everything including the door panel...but, I checked the depth of the speaker mount...3 inches. The new speakers are 2.75 inches or so...plus there might be a .25 inch clearance with the door panel. I am going to check it out and see. I am holding my breath with this project...one thing after another.
Old Oct 24, 2004 | 10:57 AM
Black Maxima
Let me know how everthing worked out.
Old Oct 25, 2004 | 05:13 AM
Well...all speakers are installed. I bought the slightly larger pioneer 6.75 inch 4 way speakers and they all fit my 97 Nissan Maxima speaker mounts. I bought the wiring harnesses for each speaker to fit the existing speaker plugs. On all four re-mounts of the new speakers, I put an extra washer on each screw for durability and snug fit.
One thing I learned in doing all of this is a new appreciation for any professional installer. It is not so much an issue of the new hu and speakers but an issue of getting at the place where you need to do the work. The time consuming thing is taking apart the car to get to all the speaker mounts.
Another thing I learned is that the car manual, Chiltons, Crutchfield and some others have incomplete information on helping you take apart the door panels, rear seat, dash etc. etc. There is always some little trick or unknown bit of information or never mentioned issue that creeps up in the process.
For example, they tell you to take the door panels completely off...I found this extremely difficult...instead...I loosened the door panels enough to work from below...I unscrewed the door panel speaker grill first using a mini-phillips head screw driver...this makes it much easier to get to the speaker mount screws.
Another example, they do not instruct you on how to remove the third middle brake light from the rear deck...almost impossible. Instead....I unclipped enough of the rear deck to get the speaker screws using a ratchet.
In all, it was a time consuming task but well worth it if you care for your car and you want to do things right.
Old Oct 25, 2004 | 11:08 AM
Jatan's Avatar
How much was the wiring harness and the speakers? What HU did you go with?
Old Oct 25, 2004 | 11:18 AM
I went with an Aiwa HU because I wanted the MP3 capability plus the front intput jack so that you can hook an Ipod or Neuros player to it...that way...you can drive around with your entire CD collection on MP3.
Old Oct 26, 2004 | 02:20 PM
Black Maxima
Hey ocean, thanks for the help. I'm going to check out those Pioneer 6.75 4-ways.
Old Oct 26, 2004 | 06:20 PM
Black Maxima
It seems like those Pioneer 6.75's would hit the grill in the door panel. The tweeter would be to tall? Same problem I had with the 6.5's.
Old Oct 27, 2004 | 12:32 AM
Crooper_Hedder's Avatar
97 Maxima Bose upgrade exact fits
Can people respond with component speaker recommendations that have an exact fit in a ~97 with Bose speakers? Thanks
Old Oct 27, 2004 | 03:42 AM
Lystat2k2se
try going to www.crutchfield.com or www.cardomain.com, then go to what fits my car, put in your year and model and then it will show you everyhting that fits the stock location or tell you what you will have to do to make it fit, i dunno if the info they give is 100% right but i have never had an issue, after you find out what fits, order it or go to the store and get the same model
Old Oct 27, 2004 | 05:26 AM
Black Max:
Just take your time with the install...it does take patience and time. The Pioneer 6.75 TSA1780's fit the screw holes on the original mounts. It is better to work with the door panels loosened. Work from underneath the door first to remove the small screws that hold the door panel speaker grill from inside the door panel. Remove the grill first and then work to get the speaker mount screws loosened. The 6.75 inch Pioneer TSA1780 speakers will fit the original screw holes with the original screws. I did not put the extra decorative speaker faces on when I installed the speakers. The tweeters do clear the door panel speaker grills when you remount the grills and door panels...they clear about a quarter inch.
The rear deck speakers are a pain to get to and mount...be careful...work slowly. You can lift up the deck panel enough to get a ratchet in to unscrew the speaker screws. Instead of screwing the new speakers with the given sheet metal screws...I used machine screws and nuts and worked from inside the trunk while my dad tightened the nuts from the deck...again, I used some washers to make a secure snug fit. Be careful with all speaker plugs and connections...the new speakers have very delicate speaker prongs that can bend and break off.
Old Oct 27, 2004 | 06:05 PM
Black Maxima
I installed a Pioneer 6.5" 3-ways with the stock mount. I just took a speaker out of my rear deck to try. The tweeter on top hit the door panel grill. I took the whole panel off, then put it back on and noticed it didn't fit.
The Infinity 6.5" speakers are looking pretty good right now.
Old Oct 27, 2004 | 11:45 PM
96pearlmax's Avatar
The only thing you need are Infiniti Kappa 652.5. Got them all around in my max and they fit perfectly with no problems. About 150 a pair but very much worth it
Old Oct 28, 2004 | 03:39 AM
Lystat2k2se
96pearlmax lol please tell me where to get your animated avatar form that thing rules... I gotta send it to my buddy who thinks his accord is the best thing since sliced bread!!!
Old Nov 5, 2004 | 02:13 PM
Analog-SE's Avatar
Good stuff to know,i ordered that setup hoping too much retro fitting wouldnt be involved. Cant wait
Old Nov 5, 2004 | 03:17 PM
huyqvu's Avatar
hmm i have alpines and they fit fine into the plastic bowl thing. and they dont hit the door panels. alpine front and rear with bass level all the way down. woo baby the tweets on the alpines are ear piercing.
Old Nov 5, 2004 | 06:51 PM
Black Maxima
I got some Pioneer 6.5" 3-ways to fit. Yeeeeeeeeehhhhhaaaa!
Old Nov 5, 2004 | 07:32 PM
DAVE Sz's Avatar
Hooooooonda.....
His didn't fit cause his speakers had a 3" mounting depth or something like that, the max can only fit 2 7/8 I think.
vingodine
45
May 21, 2016 12:46 PM
delerium75
Aug 19, 2015 11:08 AM
MikesChevelle
Aug 9, 2015 11:50 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
kjm900r
Aug 5, 2015 07:14 AM
