Which alarm is best for 5th gen Maxima
I want to upgrade to an aftermarket alarm for my 2000 SE. I want sensors for motion,windows, hood,etc. included in the system. I've heard our alarms don't go off if someone breaks the side window to reach in to pop the hood, as long as the door is not opened.
Anyone have suggestions? Which alarms are better? I'm willing to spend up to $500, as I don't want some cheap a$$ alarm, that doesn't actually work/function better than our stock ones. I posted here cause I figured I'd get more feedback, so mods please don't move this. Thanks for any and all
input.
input.
Originally Posted by Ammi
check out Viper alarms
Wow!! Thanks BRAN808 for the info. I've heard nothing but good things about Viper alarms, so that will be my first choice. I like the idea of a back-up battery. Where would be the most secure place to put it? Hidden in the trunk? I've seen some alarm remotes that have an LED screen, that shows what door,or hood/trunk is has been opened, I think I'll get that feature as well. Any other info/comments/feedback? Thanks in advance!!
Nice write up
BRAN808 - Thanks for the write-up... Now that maxima's are the 2nd most stolen cars - a nice alarm sounds like the way to go. I have seen the Viper alarms in action and they are great! I am thinking about getting one myself and will definitely use some of your suggestions.
Thanks!
Thanks!
on the back up battery idea, whats the pros and cons. i was looking into it do to the system i invested in and alot of techs gave me the same answer. they said to properly install a second battery you need it to be in a customized location do to fumes, not to healthy in general. i would like to hear if anyone has installed or actully had installed this set up.
With all of those companies being the same DEI makes viper, valet, clifford and such..... i sell the Clifford alarms and am having one installed on my truck real soon they are great. The one im gettin has a LCD 2 way remote that will warn you of break ins. there are a lot of accessories for this alarm tho some being; remote start backup battery siren, auto window rollup, and glass break sensor. so whatever you want to add on can connect right to the brain.
I've talked to a friend of mine who has a Valet alarm system, it looks and works good. LCD remote shows which part of car is being tampered with: hood,doors,windows, trunk.His opinion was that Alpine made some of the best alarms, and that they cost $$$$. He also thought Viper and Valet were very good choices. He suggested the following options when buying my alarm,
1.) Motion sensor
2.) Wheel/suspension sensor- if the thieves start jacking up the car,alarm goes off.
3.) Window sensors.......breakage and shock
4.) Back-up battery.......placed in unusual/secure location
5.) Back up siren...........placed in hard to get at location under car
6.) locating Alarm ECU in unusual location inside car
7.) Hood lock
What else should I consider?
1.) Motion sensor
7.) Hood lock
from what ive been researching, g5 technoogy, while good, isnt AS GOOD as g4. after DEI took control of clifford, they kinda streamlined things. i have a g4 on my old car & am trying to decide whether to take it off or buy g5. the avantgaurd is a great alarm, just not as feature packed as its g4 counterpart. IMO
i know its an OLD TOPIC...But how is python?
i know DEI owns them as well as viper, but my cousin just had a python 2way system installed in his car a few days ago, and im thinking of getting one installed as well..i also see that on the viper and python models...i dont see a keyfob with the trunk latch release button. I was wondering if i would use my capability to pop my trunk latch remotely
Python,Viper and Clifford Matrix are all one in the same. They have dedicated trunk release outputs.
1.) Motion sensor
7.) Hood lock
1.) Motion sensor
7.) Hood lock
Personally I feel you could probably do without the motion sensor and go with just the tilt sensor (option 2 on your list). If they tweak that motion sensor you could be in for along night. I had one installed along with the tilt sensor and it got very windy the night it was installed. Needless to say being woken up several times of the night due to false readings was not good. I instantly had the motion sensor disconnected (it is still in the car) and just left the tilt sensor. I also have the battery back up and window sensors. As far as an additional hood lock, I think of it in this way, the only way they can access your engine bay area is by either getting inside the car (at which point your alarming should be going off) or somehow popping it from the outside (which will require enough force to trigger the shock and set off the alarm),it's an available option but is completely up to you if you think you need it.
I think you have all your bases covered with what you listed.
1.) Motion sensor
7.) Hood lock
1.) Motion sensor
7.) Hood lock
I think you have all your bases covered with what you listed. I have a Clifford Matrix 3.5.
thanks alot for all the insight fellas, ill probably get the Python alarm system installed with that Color LCD....the local shop in my area is charging 700 bucks for EVERYTHING, even for the remote starter bypass...u think 700 bucks is a bit steep?..........or is that about right?
dunno if u have went with an alarm yet..... but i have an 03 mustang cobra vert that i use the clifford g5 and had a 75 impala that u could steal with a screwdriver on 22s that i had a clifford g4 protecting..... both alarms do what u mentioned u want and have a cool feature called black jack that requires a code to be entered to drive the car or it wil die after about a minute and be dead in the water with the alarm blaring even if the theif has the keys....install for me was 5-600 bucks.....
Lakersallday24
Nov 7, 2024 07:31 PM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
