Radio Cut-Off
Old Oct 27, 2004 | 12:57 PM
aziphrale's Avatar
Radio Cut-Off
The Radio in my car cuts off and resets everytime i turn the car off and on. its annoying as hell to reset all the presets. I didnt do the wiring and thats how the car was when i bought it. The only thing that i did was run connectors to the rear speakers cause it was off. Is this suposed to happen cause its an 89 or did they do a bad install. thanks in advance.
Old Oct 27, 2004 | 08:07 PM
erty67's Avatar
Decal Specialist
I'd guess on the bad install. If you take the HU out, the yellow wire needs to be connected to a constant voltage wire.(always has 12V on it, even with car off) It sounds like it is connected to an ignition wire, meaning that it goes to 0volts when you shut the key off.
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
mikeg75
Nov 30, 2015 05:12 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
