Is this true?
Old Nov 2, 2004 | 08:04 PM
01GLEGRAY's Avatar
Is this true?
I was talking to a crutchfield advisor. He told me that I will get line noise if I use the PAC AOEM-NIS2 with an aftermarket amp and speakers. Is this true? I don't know if I should believe him or not. I am new to car audio. Please advise.
Old Nov 2, 2004 | 08:13 PM
DJ Kontakt's Avatar
whats the PAC AOEM-NIS2 ?
lol
I might be able to help, too lazy to look this number up.
Old Nov 2, 2004 | 08:15 PM
01GLEGRAY's Avatar
It converts the bose h/u to 4 RCA outputs
Old Nov 2, 2004 | 09:52 PM
yogi's Avatar
u shoud not get the noise....but u may.....it's really hard to say
Old Nov 3, 2004 | 04:21 AM
Pearl96Max's Avatar
I tend to get a bit irritable
mostly depends on the rest of the install. Although the PAC "adaptor" isnt even needed....
--Don
Old Nov 3, 2004 | 05:37 AM
krasavchic's Avatar
I use PAC... sounds fine... It has a ground loop isolator built-in
Old Nov 3, 2004 | 06:14 AM
UGAd13's Avatar
I use that harness, no problems here. It's hooked up to an Xtant 1001d w/ 3 JLAudio 12s. Also make sure you run the power wire down the opposite side of your car that you run the RCAs to further reduce line noise.
Old Nov 3, 2004 | 06:53 AM
GaMax97GLE's Avatar
I also have the PAC AOEM-NIS2. No noise from it. Though the remote turn on wire (blue/white stripe) didn't work with the CD funtion. So I just tapped into the rear Bose sub power wire.
I doubt Crutchfield carries PAC so he may have wanted to sell you something else.
Old Nov 3, 2004 | 07:03 AM
Z Man's Avatar
I have the PAC AOEM-NIS2 installed with my Bose and there's no line noise at all. I think it sounds great. In fact, I used to have a Blaupunkt HU installed and had a lot of engine noise with that. Putting the Bose back in and using the AOEM-NIS2 actually solved the problem for me.
Old Nov 3, 2004 | 02:15 PM
01GLEGRAY's Avatar
--Don
Can you further explain this? I was under the impression the adaptor was needed to level out the signal to the amp.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Gingerheadman
Oct 1, 2015 05:11 PM
Sep 27, 2015 08:37 AM
