1/2 or 3/4 inch screws for amps
Old Apr 15, 2001 | 03:23 PM
tony
Howdy all:
I have just finished installing a 3/4" piece of MDF on the seatback of my 96 Maxima. I have two MTX amps to mount along with distribution blocks. Do I need to use 1/2" or 3/4" wood screes. I am thinking that because they have to go through the feet of the amps and blocks I should be able to use the 3/4"?? But I want to check first because I do not want to screw it up. If the suggestion is to go with 1/2" are they strong enough to hold amps up against the seatback without falling off.
As always I appreciate any feedback you can offer.
Best regards,
tony
Old Apr 15, 2001 | 03:53 PM
Micah95GLE's Avatar
Either one will work. Try holding the 3/4" screw next to the edge of the MDF and see how far it will stick up. It shouldn't be much, but you could use a washer or two if you need to.
Old Apr 15, 2001 | 09:32 PM
Matt93SE's Avatar
STFU n00b!
usually the 3/4" screws will hold fine, but I actually recommend drilling through to the other side, then mounting them with longer machine screws and t-nuts.
Cost is considerably more, but it's very secure and looks great compared to something fastened together with black drywall screws!
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
