Replacing stock bose headunit with aftermarket, and keeping bose speakers, questions
Old Nov 3, 2004 | 02:54 PM
gto400no1's Avatar
Alright so my stock bose headunit is making a really annoying noise from the tape deck and i have no clue how to fix it so i am going to purchase a new headunit. i have heard that there are a few headunit replacements that you do not need a converter such as the ROEM-NIS2, is that true? if so i have heard that many if not all alpines are able to be used without the converter, being as they have the 4volt preamps, am i correct still? So now if that is the case i am looking into getting the CDA-9833, with that will i be ok? also will the stock bose speakers be alright with this headunit? heres the link for the headunit http://www.crutchfield.com/S-WuAars2...01&search=9833. any feedback on that headunit or models that are very similar such as the 9835 or 9831 would be greatly apprectiated.
-Tom
Old Nov 3, 2004 | 06:53 PM
gto400no1's Avatar
bump bump... nobody knows?
Old Nov 3, 2004 | 08:14 PM
maximus nismus's Avatar
i have a alpine myself. since you have bose you have to do couple things:
find where your amp for the speakers are (usually in the trunk next to your sub.)
use a 9v battery and tape wires to the terminal (this will "pop" your speakers to find
out what wires are the speakers.)
alot of pATience to find the speakers, prolly need another person to tell you where the speakers are popped
the speaker will be 2 wires wid (-) and (+)
they usually are same color/pattern bbrighter colors=(+) darker (-)
strip the wire of the speakers so that it does not go back to the amp (this is how you bypass a oem amp)
after this dont plug the plug back the amp and sub is useless...well for me anyways
once you taped it CLEANLY (do it right or dun do dat ****)
it should work, but when i did mines the sub didnt work so i sold it
Old Nov 3, 2004 | 10:58 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Im sure you took a bit of time to do and type this, but it isnt needed at all. Use your aftermarket preouts as your source. Factory amps will still be intact and used with the new HU. Anyone that needs more info on how to do it, feel free to post here or PM/email me..
--Don
Old Nov 4, 2004 | 07:55 AM
Dr.Monkey1313's Avatar
I have an Alpine XM/CD headunit in my I30 and am using the Bose speakers. All that needed to be done was to bypass the Bose Speaker amps and use the headunit amp. Or you could bypass the headunit amp and use the Bose speaker amps. Either way.
Basically, you CAN have an aftermarket headunit in our cars and still use the Bose speakers despite what some people out there say.
Old Nov 4, 2004 | 01:22 PM
gto400no1's Avatar
im still a little confused, do i have to do any modifications or is it plug and play for the most part?
Old Nov 4, 2004 | 07:39 PM
factory amp has rcas?
im lost what do u mean don.
he wants to replace his HU is what i got from readin his post.
Old Nov 5, 2004 | 01:40 PM
Pearl96Max's Avatar
No it does not. What I meant was..to install the aftermarket HU you will need a wire harnes (Metra P/N: 70-7550) Instead of connecting the speaker leads to that of the aftermarket HU harness wire them to Male RCAs then plug them into the preout section of the aftermarket HU. From the OEM/Bose HU all that the speaker leads do is serve as a signal. Doing it with the RCA method ends in the same result of only sending a signal to th Bose amps.
--Don
MikesChevelle
Nov 23, 2024 11:17 AM
jskirwin
Jun 8, 2016 08:49 AM
Abdelrhman
Aug 17, 2015 12:16 PM
MikesChevelle
Aug 9, 2015 11:50 AM
PhalC1
Aug 5, 2015 02:36 PM
