how do u run the amp wires
if your talkin about power and rcas, run them one on each side. for power...drill a hole through your firewall, careful not to pierce anything in your engine, usually there is like a little cut out inside your car on the wall....use that as a guide. run the power like that and the rcas on the other side of the car under you door sills.
yeah, if you don't have a clutch, there is a diamond piece of carpet you can remove and drill through to run the power. After that, it's all tucking and hiding. It can be a pain, but you'll appreciate the results if done right.
The Frye
Sep 2, 2021 11:03 AM
