what are you guys using...?
Old Nov 15, 2004 | 09:20 PM
eckohb's Avatar
what are you guys using to keep your sub box from moving around in your trunk? ive got my 2 ten inch sub woofers in back, and the box just moves around a lot. im just wondering what you guys use to keep it stationary.
Old Nov 15, 2004 | 09:29 PM
AscendantMax's Avatar
sheer weight
box and sub prolly weighs a good 80 pounds...kinda broke that cardboard under the carpet
but i would try to L-brackets to secure your box down.
Old Nov 15, 2004 | 09:31 PM
eckohb's Avatar
total my subs and box is prolly 150+ lbs, so that doesnt do it. the trunk goes up at a slight angle, which i think causes it. i thought about L - Brackets, but wasnt sure how they would hold up. Hmmmm....
Old Nov 15, 2004 | 10:33 PM
thephatOne's Avatar
i heard of people using carpet tape, but i have yet to see it
Old Nov 15, 2004 | 10:36 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by Fosgate Fan
sheer weight
Beat me to the punch Gordon
Old Nov 15, 2004 | 11:51 PM
slickrick's Avatar
you need more than t he weight of the box unless its shaped into the trunk. get some cheap plywood and put it under the trunk then drill the l brackets into it. no more problems for me.
Old Nov 16, 2004 | 01:12 PM
Originally Posted by slickrick
you need more than the weight of the box unless its shaped into the trunk.
about that...my box made an imprint of itself on the carboard...so it kinda sits in this indentation
i gotta fix that when i have time
Old Nov 16, 2004 | 01:18 PM
2 Da Max's Avatar
yea i have a single 12 and it just bent right into the cardboard, so i dont really worry about it moving around
Old Nov 16, 2004 | 09:20 PM
eckohb's Avatar
ill go with the L-brackets idea since the sheer weight idea doesnt work for me
Old Nov 16, 2004 | 11:28 PM
merovi's Avatar
i did L brakcets
Old Nov 17, 2004 | 05:39 AM
blackmax01's Avatar
In my 01 i have hooks for the cargo net and wrapped the cargo net pretty nice around the sub and it holds it really well right up against the back seat.
Old Nov 17, 2004 | 12:02 PM
mendon99's Avatar
tastey wheat
L-brackets would work and look best, i use 1 long bungee cord and strecth it across the width of the trunk, looks retarded but i dont care its not for show really
Old Nov 17, 2004 | 05:19 PM
KCMaxima98's Avatar
I used L brackets too. I just secured them into the wooden cover for the spare though. I was scared to put self tapping screws into the metal.
Is it safe to drill into the rear area of the trunk floor?
Old Nov 17, 2004 | 05:58 PM
2 Da Max's Avatar
y not? i would if i had to
Old Nov 17, 2004 | 06:18 PM
yeah it should be ok, just make sure you don't hit anything important like fuel lines, brake lines, etc etc. also paint over any exposed metal to prevent rusting.
Old Nov 17, 2004 | 06:52 PM
Lytheum's Avatar
carpet tape...one strip holds my 100lb sub/box in place
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
