MTX 801D mono amp + kicker L5 15" 2ohm not kicking enough
Old Nov 19, 2004 | 01:53 PM
NYghettoGLE's Avatar
i recently installed a MTX 801D mono amp + kicker L5 15" on a ported box.
everything else is stock bose, including the head unit.
i don't know if it's me or the system, but i'm kinda dissapointed at the results.
i wanted a strong hitting bass when i listen to rap, but instead i get a helluva lot of rattling, i mean the whole car starts to shake, i tried playing with the amp gain, but too low gives me no punch, and too high gives me some punch but way too much rattling, i mean my steering wheel starts to shake so bad, is not funny.
would a aftermarket HU give me more punch with less rattling?
or is it supposed to be like this....
Old Nov 19, 2004 | 01:58 PM
SublimeI30t's Avatar
You definitely need to look into sound deadening. Look at this http://forums.maxima.org/showthread.php?t=352271 for suggestions on which kind.
Old Nov 19, 2004 | 03:07 PM
AscendantMax's Avatar
if you want a more punchy bass then I'd put that thing in a sealed box. either way, i'd look into some sound deadening like sublime suggested. seems like you hear more rattles than your bass.
Old Nov 19, 2004 | 04:02 PM
slickrick's Avatar
how big is this ported box and tuned to what? id probably put it in a sealed box with all that power you have for it.
Old Nov 19, 2004 | 04:52 PM
Manaz101's Avatar
When i was shopping around for a box for a 12 i used to have.....i found that the same sub in 3 different boxes (sealed & ported & bandpass) with the same amp sounded waay different. I ended up getting a bandpass for my particular application, but i would suggest the same as the others have. Change the box and see what results you get. You usually get "cleaner" thump from a sealed box.
Old Nov 21, 2004 | 03:33 PM
well, the box is a cheap one i got from ebay for 30 bucks..........
as for sound deadening......that way too advanced for me, i'm so sloppy at cutting and installing anything, i always mess up with anything sticky.
what the difference between all 3 box types?
Old Nov 21, 2004 | 05:42 PM
fstbusa's Avatar
check this site out... has info on all different types of enclosures.
http://www.lightav.com/car/boxes/boxes.html
Old Nov 22, 2004 | 01:31 PM
Well, changing the box to give more bass than is already present, seems as if it might create more rattles in the process. Try a different box, but it sounds like youve got a lot of rattling going on, which will be fixed with deadening. If you are that bad at it, get a friend to help you, or get a professional place to put it in.
sliptap
Sep 30, 2015 05:57 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Redfox
Sep 28, 2015 10:41 AM
