Rate My Car Audio!
Old Nov 19, 2004 | 06:41 PM
metallic97gxe's Avatar
Master Will
Rate My Car Audio!
Rate My Car AudioHERE
Thank You!
Old Nov 19, 2004 | 06:55 PM
AscendantMax's Avatar
gave ya 10 across the board
Old Nov 19, 2004 | 08:13 PM
2 Da Max's Avatar
i gave you a ten for everything, are you going to cover or wrapt that box?
Old Nov 20, 2004 | 12:23 AM
Master Will
thanks
this box is temporary until I get my fiberglass setup we are doing soon....it just shows my local customers the kind of boxes we build...
Old Nov 20, 2004 | 04:44 AM
LeX's Avatar
LeX
Nissan by Nature
It all sucks.....
of course it's good man, ur **** is always good 10s
Old Nov 20, 2004 | 09:09 AM
2 Da Max's Avatar
Originally Posted by metallic97gxe
thanks
is that some kind of band pass box? and not to be nosey, but would the fiberglass box be the same way too? and do they bass as good in fiberglass compared to mdf?
Old Nov 20, 2004 | 11:10 AM
mendon99's Avatar
tastey wheat
nice boxes, nice car.. 10
Old Nov 20, 2004 | 01:51 PM
Master Will
the fiberglass box will be different you will see...no this box is not a band pass box..
http://www.cardomain.com/memberpage/24211/6
Old Nov 21, 2004 | 09:18 AM
2 Da Max's Avatar
dam those are some sick setups
Old Nov 21, 2004 | 06:44 PM
Master Will
thank you!!!!!!!!!!
Old Nov 21, 2004 | 07:00 PM
sachmo12345
8 only because the subs could be upgraded
Old Nov 22, 2004 | 03:51 AM
Master Will
opinions on subs depends on how much you can spend, what's avaliable in your area, what everyone else has, what you've heard of before, and personal experience w/brand x....etc..etc..
Old Nov 24, 2004 | 07:52 PM
Master Will
I just put a Treo ssi sub in tonight dual 2 ohm voice coils man this thing is clean and loud getting 750 watts rms from an hc ma audio amp...pics later...
Old Nov 24, 2004 | 09:26 PM
2 Da Max's Avatar
WTF 750 rms? dam, ever though of running 2 subs?
Old Nov 25, 2004 | 04:49 AM
Master Will
if you heard my setup one sub is all I need....
Old Nov 25, 2004 | 06:45 AM
Master Will
New updates as of last night....
I installed a MA Audio HC2501 Amp (4OHM=250 Watt RMS, 2 OHM 450 Watt RMS, 1 OHM 750 Watt RMS, 0.5 OHM 1250 Watt RMS)
The amp is mounted on the back of my sub enclosure
http://www.rankmyride.com/data//e/8/...ohc1250amp.jpg
I’m running it 1 Ohm to my TREO Engineering SSI Dual 2 Ohm Voice Coil 12” Subwoofer
this sub rocks this is true SQL loud and clean.....
I also upgrade my 8 gauge power wire to 4 gauge w/a 70 amp circuit breaker and I added an Audiobahn 1 farad capacitor and a APC fire extinguisher on my accessory/amp rack in my spare tire area...
http://www.rankmyride.com/data//e/8/...tinguisher.jpg
we are designing a fiberglass setup for 2 JL Audio 10w3 10” subwoofers for my next setup...I bought the TREO to use in my next project car but I might a s well use it now until I get my car next year...
my old setup was a Audiofonics 12” sub and a Stinger 0.5 farad capacitor and an MTX 421D amp...I hit 139.8 DB w/this setup I hope to be in the 140’s w/this TREO sub...
http://www.onlineshowoff.com/media/photos/o_3088.jpg
http://www.rankmyride.com/data//e/8/...e/100_9375.jpg
Old Nov 25, 2004 | 08:42 AM
looks good!
Old Nov 25, 2004 | 08:44 AM
2 Da Max's Avatar
hey did you feel a difference when you switched to 4awg wire? btw how much does a box like that cost?
Old Nov 25, 2004 | 02:11 PM
Master Will
yeah the 4 gauge wire helped out a lot...
the sub enclosure I have we buld them for....
$150.00
Old Nov 26, 2004 | 03:32 PM
minsbang's Avatar
i'll give ya 1.
that's 1 nice setup.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
twotonezed
Aug 16, 2015 08:10 PM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
