AMP Probs
Old Nov 24, 2004 | 09:11 PM
jackiss2888's Avatar
AMP Probs
Ok, got a BOSE headunit and am trying to hook an amp with 2 12" subs up. The remote wire and RCA wires are sliced into the rear speakers and the power and ground are both hooked properly. The subs hit, but defintely not as hard as they should. The exact same subs and amp were takin out of a friends car and they sounds nearly unbearably loud, but in the Max they hit , but defintely not as hard as they should.
Does anyone have ANY clue? I really need you help...
Old Nov 24, 2004 | 09:12 PM
2 Da Max's Avatar
do you have a high low adapter?
Old Nov 24, 2004 | 09:18 PM
No, can you please explain?
Old Nov 24, 2004 | 09:19 PM
by the way, its not RCA, i meant to say line level inputs, if it makes a diff.
Old Nov 24, 2004 | 09:33 PM
f550maranello2's Avatar
thats cuz its the bose unit... it sucks a$$. it has active equalization wich makes the sound very flat sounding. i have the same setup as u do. my system came out of my old car (thunderbird) and i have to say that it sounded a lot better in it then i does in my maxima. Try getting rid of the bose if u can thats what i did and im very happy without it. Also i have to say that you are right bout the bass just hitting hard. I still havent figured that one out, i have a good equailzer built in my headunit and i have the singal wires connected tothe rear speakers (line level or high level input however u want to call it) let me know what u figure out.
Old Nov 24, 2004 | 09:37 PM
f550, i foudn soemthing called the AOEM-NIS2 . Check it out and let me know what you think.
Old Nov 25, 2004 | 01:47 AM
Maximeltman's Avatar
ya i kept the bose hu in order to not attract jackers. ive been jacked before it suks much ***.
Old Nov 25, 2004 | 05:40 AM
Just out of curiosity, what does that have to do with anything?
Old Nov 25, 2004 | 05:17 PM
just sayin i did the same thing as you, potna! why you buggin gangsta?
j/k
if your subs don't hit hard enough, cut the ohms in half or wire them differently. turn the gain higher. buy a more powerful amp... mine hit real hard, in a ported box, with a 4ohm stable amp that only pushes 75wx2, but i wired it to 2ohm, and now i'm gettin about 200 per channel with no probs but i need a new one. also, your friends car might have different design that amplifies the bass more than your car does.
Old Nov 25, 2004 | 05:22 PM
also have a low-pass filter
Old Nov 25, 2004 | 05:57 PM
Guinader's Avatar
well would a bad ground connecting have anything to do with it... I thought my ground was fine, but I realized it wasn't until someone fixed for me.
Old Nov 25, 2004 | 06:00 PM
A32Matt's Avatar
dude, go with the line level inputs. hook them up to your rear speakers like you have the RCAs. I don't know if it's a good idea to hook RCAs up like that. Where do you have the remote line hooked up to? A bad ground would cause the subs to not hit properly, but i'm pretty sure it's how you have the inputs to the amp.
Old Nov 25, 2004 | 07:04 PM
My friend's car is also a 4th gen max, and Matt, what do you mean line level inputs liek teh RCAs? please speak lamans terms for me. thanks.
Old Nov 25, 2004 | 08:58 PM
A32Matt's Avatar
no, if you look on your amp, there is this white plug....get line level convertor from your local audio store and splice them bad boys in and plug it in.
Old Nov 25, 2004 | 09:56 PM
already done that man
Old Nov 25, 2004 | 10:04 PM
A32Matt's Avatar
huh? so you have RCAs and line level input at the same time? i'm not sure i understand...if you do then you need to at least get rid of the RCAs.
Old Nov 25, 2004 | 10:09 PM
HoLLaAtMyMaXx's Avatar
sry to get off the subject but can someone tell me whats the big hype with BOSE? just wondering cause i hear phenominal things about like pioneer and others just wondering why many people on the site perfer BOSE... maybe i will get one also....
Old Nov 26, 2004 | 07:13 AM
tommyali
bose so good because its a stock system from factory and its really good quilty, not many cars stock have good mids and highs. Also the bose system good some good bass to it
Old Nov 26, 2004 | 08:44 AM
Ok, I have the remote to the back speakers, the line level inputs to the back speakers, and the power& ground running to their places. The bass IS hitting, but not nearly where it should be.
So i need soemthing else? i found this PAC AOEM-NIS2 . What does this do and do i need it?
Old Nov 26, 2004 | 08:46 AM
like tommy said, its just the fact the if your not into aftermarket audio, BOSE is great becaseu is a quality system that can come factory installed with the car. on other hand, its a pain in a hole to do anything with it, considering everythign is individually amped...
Old Nov 26, 2004 | 08:51 AM
97maxxx's Avatar
hey man u can always just run a line out converter from your headunit like i did and then that gives you your rca out and u can run everything from there -i have great sound and there is no need for splicing -its really easy and everything still looks totally stock
Old Nov 26, 2004 | 02:34 PM
97maxxx, are you talking about the PAC AOEM-NIS2 ?
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
