Driing lights/ Fogs.
Old Nov 29, 2004 | 02:56 PM
aziphrale's Avatar
Has anyone installed driving lights/fogs on there car that didnt have it before? My max didnt have fogs when i got her. And i just bought some from another orger. Can i run the remote that came with it threw the firewall without making a hole. Or should i just hook it up to stock wiring that when i turn on lights the come on as well? The reason i ask is i have the angel eye lights that was in the gd. And you press 1 angels come on press again and the lights press again and both off.. I want both on at once. Anyone that has an idea let me know thanks. Its an 89 max.
Old Mar 25, 2005 | 04:49 AM
NelsonSheikh
If you are a fast driver with a powerful car & ***** of steel checkout our official website: w w w. u l t i m a t e r a l l y . c o m
Greetings,
K i m b l e
Founder of the Ultimate Rally.
w w w . k i m b l e . o r g
Old Mar 25, 2005 | 05:52 AM
kcidmil's Avatar
Well if you want to keep just both light working, I'd hook it up to the stock wiring. But if you want to switch between you'll need to use the wiring that came with it.
Old Mar 25, 2005 | 05:59 AM
brettb's Avatar
O'rly
Greetings,
K i m b l e
WTF
Old Mar 25, 2005 | 06:55 AM
kcidmil's Avatar
Actually I read through the post a little better. If you do hook it up to your wiring... make sure to use the relay that came with it. You can tap onto the signal wire for the headlight relay and use it to activate the fog's relay as well.
The Frye
Sep 2, 2021 11:03 AM
doctorpullit
Apr 23, 2017 05:35 AM
mpbclutch33
Dec 26, 2015 11:11 AM
fastcarny
Oct 12, 2015 07:06 AM
