finding hole in firewall
Old Dec 12, 2004 | 12:13 PM
hardcorefubu's Avatar
i have a 00' GXE and im putting a system in with 2 12's and i can't find a hole in the firewall. im using 4 guage wiring so it has to be a good size hole. does anyone know where there is one or did you guys drill? if you did drill, where did you drill? thanks.
Old Dec 12, 2004 | 05:14 PM
craig10114's Avatar
if ur an auto then look up where the clutch pedal SHOULD be. there will be a peice that looks like it can come off. rip it off and it will expose bare metal, if u look in your engine bay u will see that same shape its right next ot the master cylinder. Drill that spot with a .5 in bit and ur set. Make sure to use a gromet or some sort of protectant on your wire to make sure chaffing dosnt cause bare wire to be exposed.
Old Dec 12, 2004 | 05:19 PM
sachmo12345
i ran mine right through the mud guard on the drivers side wheel well worked out perfectly you be able to see an inch of wire when the door is open if taht matters to you
Old Dec 12, 2004 | 06:39 PM
my car is manual...and i had it ran through the door before but i am wiring a second amp in and im tired of having exposed wires. any other ideas? please
Old Dec 12, 2004 | 08:25 PM
craig10114's Avatar
i belive right above the brake pedal is room to drill, look in your engine bay u should be able to get an idea of the area, ive drilled one car here but the whole was already there i just enlarged it
matts95max
Apr 23, 2025 10:44 AM
Vistance
Sep 17, 2015 05:17 AM
bbsitum
Sep 11, 2015 04:55 PM
adamgalazka
Sep 8, 2015 01:27 PM
maximusrising
Sep 2, 2015 09:55 AM
