help with head unit!!
Old Dec 19, 2004 | 01:17 PM
Maximeltman's Avatar
I know it should be in the audio section...but I need a quick answer on what the black two-prong connector is in the back of the stock head unit?
my new head unit doesn't work and I was wondering if it has to do with that two-prong connector that is black. when i put on the two white connectors it didn't fire up, when I tried the two prong it did, and just bought a harness for the alpine hu and it doesnt come with a way to attach the black two-prong connector, do i need a special part or what?
thanks guys.
Old Dec 19, 2004 | 02:00 PM
jackiss2888's Avatar
Its just the antenna wire. No worries. I am rather experienced with our BOSE hu's, so let me know if you have any other probs.
Old Dec 19, 2004 | 03:53 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you need a double diversity antenna apapter. the 2 prongs are for you antennas, you have one in the rear windsheild and the antenna itself. get the adapter and your headunit will work, if not check the inline fuse for the headunit.
Old Dec 19, 2004 | 05:26 PM
Old Dec 19, 2004 | 09:12 PM
Saddles's Avatar
Dont forget the power antenna wire. The adapter is nice and all...but, antenna still doesnt do much good without it going up, if you plan on using the radio. Forgot the color
Old Dec 19, 2004 | 09:36 PM
killcrap's Avatar
its the black with red tracer.
Old Dec 19, 2004 | 10:15 PM
i got that bish up an' runnin!
now for a space-filler...
Old Dec 19, 2004 | 11:15 PM
Irish's Avatar
This is a democracy
you can get one from crutchfield or a local shop should have one too. i think mine was like 20 bucks
Old Dec 19, 2004 | 11:21 PM
allrightythen!
also, anyone know how to fix the 'burp' when powering off?
Old Dec 19, 2004 | 11:28 PM
Irish's Avatar
This is a democracy
better ground
Old Dec 19, 2004 | 11:30 PM
thanx Irishmax!
Old Dec 19, 2004 | 11:40 PM
Irish's Avatar
This is a democracy
no problem, are you hooking up a system or just replacing factory headunit? did you have bose?
Old Dec 20, 2004 | 11:09 AM
ya put in an alpine hu.
stock bose speakers, 2 treo ssi in a built dual 12" ported box that i made.
saw your box on cardomain, looks cool.
Old Dec 20, 2004 | 10:40 PM
warmax918's Avatar
heres a tip:to get better tuner reception when using an aftermarket antenna adapter wrap a few strands of wire w/out insulation around the two prongs on the original antenna plug and then plug into the adapter. You only need about 6in. of wire. Also the factory head unit doesnt have a true ground it uses the antenna for a ground. So when installing an aftermarket HU make your own ground. I used one of the 10mm bolts on the tranny hump.
Old Dec 15, 2005 | 07:13 AM
ypl102's Avatar
you can also take the HU's ground wire and attach to the hole in the back ground plan of the HU itself, this will put it on common ground as the antenna. Grounding to the chassis didn't work for me.
aw11power
Oct 10, 2021 04:57 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
