How Do I Run My Amp Wire Through The Firewall??
Old Dec 20, 2004 | 08:34 PM
2kVQboodah's Avatar
i wanna run my amp wire w/out drilling. how do i do that??? i got a 5th gen 5 spd. i heard for the manual cars, its a little harder then the automatics.
Old Dec 21, 2004 | 01:33 AM
nyautostyle's Avatar
hmm, look for some gromments around.. if u have to drill you have to drill, thats it.
Old Dec 21, 2004 | 11:08 AM
SPiG's Avatar
SomePsychoGuy
In a 4th gen there is a big grommet in the driver side fender. Look in there.
Old Dec 21, 2004 | 03:41 PM
2kVQboodah's Avatar
awww this gunna be a b*tch.... any other pointers???
Old Dec 22, 2004 | 08:21 AM
wadamax's Avatar
I just ran my last week. There is a rubber grommet behind the driver side wheel well cover. There are about 3 or 4 screws that you will have to remove. Once you bend the cover back, you should see the grommet. You will need something sharp to poke a hole through it. Also, you will have to jack the car up and take the wheel off to make it easier.
Old Dec 23, 2004 | 05:38 AM
2kVQboodah's Avatar
i THINK i found a hole on the passenger side... not sure.
Old Dec 23, 2004 | 10:23 AM
2 Da Max's Avatar
uhm.. what the fawk is a grommet? sounds like a british biscuit
Old Dec 23, 2004 | 05:09 PM
2kVQboodah's Avatar
i think he meant the rubber thingy... haha
Old Dec 23, 2004 | 10:47 PM
BlkShadow01
biscuit
hahahahahahghahaha 2 da max is the biggest pimp man hes pims all ThA hoez
Old Dec 25, 2004 | 01:44 PM
djfrestyl's Avatar
Suspension Yoda
with 5spd cars the area where the clutch master cylinder is would be where you could easily drill and feed a wire through
-but im 95% sure there are still grommets around...look for where your throttle cable goes through,or where your hood latch release goes through
Old Dec 25, 2004 | 03:02 PM
2kVQboodah's Avatar
do you have a system djfrestyl?? if you do how'd you run it through??
Old Dec 25, 2004 | 03:07 PM
djfrestyl's Avatar
Suspension Yoda
yea i have a system
i dont have a 5 speed so theres a hole drilled next to the power steering module right where the clutch would go
Old Dec 26, 2004 | 09:02 AM
2kVQboodah's Avatar
ohhh ic.. i'll check that out whenever i got the chance. thanks!!
Old Dec 26, 2004 | 09:09 AM
BP2K2Max's Avatar
i ran my amp wire under the molding for the driver door and then under the fender into the engine bay then i ran it under the kickplate into the back to the amp. it's been working fine for the last year and a half.
like this:
Old Dec 26, 2004 | 10:08 AM
kman3k1's Avatar
I did the same thing as wadamax. Once you get through the firewall though, its a pain in the a$$ to pull the wire out under the dash. you can do it though
Old Dec 26, 2004 | 08:38 PM
2kVQboodah's Avatar
thanks for the pix bp2k2max. does the door close onto the wire?
Old Dec 26, 2004 | 10:19 PM
BP2K2Max's Avatar
no, that was my main concern. there is about 3/4 of an inch of clearance between the fender and car body. with the door closed i can still get slack from the wire.
Old Dec 26, 2004 | 10:29 PM
huyqvu's Avatar
drill a hole. thats what i did. well i was tired, cold, and the getting late. drilled a hole and be sure you use your own grommet so the firewall doesnt cut the power line.
The Frye
Sep 2, 2021 11:03 AM
captchaos
Mar 15, 2016 12:18 PM
