why is my amp overheating??
Old Apr 22, 2001 | 01:45 PM
bosco500's Avatar
I have just installed 2 rockford punch2 12's and a power 400a4 pushing them. The 12's will play for about 10 seconds, and then the amp is too hot to touch!! why does an amp overheat? The guy I got the 12's from told me to wire them like this. He said run the positive on one speaker to the positive on the other speaker, and run the negative the same way, and then hook up as usual. Is this correct or is this my problem? Any help will be greatly appreciated~!!!!!
Old Apr 22, 2001 | 01:48 PM
loudmaxima's Avatar
what ohm speakers? SVC or DVC?
Old Apr 22, 2001 | 01:56 PM
bosco500's Avatar
to tell you the truth I dont know.. I dont think they are DVC.. they were only 85 bucks a peice. Does this matter?
Old Apr 22, 2001 | 01:59 PM
ispeed's Avatar
Sounds like you have them running in a parallel config. If you have the amp bridged you are most likely running a 2 ohm mono load. To my understanding that amp is not stable to 2 ohms in mono.
Actually, just thinking about it you have subs wired to the same channel or you have it bridged (has to be from the way you descibed wiring.)
you will need to either wire in series while the amp is bridged, or put 1 sub on one channel and the other sub on the other channel. not running the positive from one speaker to the other. but from amp to speaker.
Old Apr 22, 2001 | 02:03 PM
bosco500's Avatar
ok i'll try doing that.. i'll let you know what happens in about an hour.. thanks!
Old Apr 22, 2001 | 02:04 PM
loudmaxima's Avatar
not really but i'll try ;]
ok .. just do this if they are single voice coils... bridge channels 1/2 to one speaker and bridge channel 3/4 to the other speaker should be 2(two) 4ohm loads which that amp should be able to do
Old Apr 22, 2001 | 02:52 PM
bosco500's Avatar
thanks everyone for the help. I just took off the wires running from speaker to speaker, and ran just speakers to amp, and it is hitting like HELL!! thanks!
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
