safe firewall drilling
Old Dec 28, 2004 | 04:30 PM
jzq's Avatar
jzq
I have a 99 maxima and I need to run a power wire to my amp. Where is a safe place to drill? If anyone has pics that would be nice.
Old Dec 28, 2004 | 05:56 PM
sunten1
i would assume that the best place would be right on the drivers side firewall. and run wiring under the carpet
Old Dec 28, 2004 | 09:16 PM
96GreenMax's Avatar
In the 4th gen specfic forums in the stickies it explains about a grommet on the driver side behind the plastic cover. If you remove the wheel well cover on the driver side there is a very large grommet sitting ther that you can run pretty large gauge wire through. I have 4 gauge going through there and I beat if you took time you could get 0-1 gauge or so through there. A lot better then drilling. If you you need help it is in the stickies or you can PM me if you want
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
Socalstillen
Sep 26, 2015 12:01 PM
dcam0326
Sep 18, 2015 04:52 PM
