the big three?
Old Jan 2, 2005 | 08:24 PM
Maximeltman's Avatar
the big three?
ok. i guess 4 gauge is what is needed. my battery ground looks like it's already 4 ga. (it's black with a red streak).
I can't even begin to see the wires for the alternator, there seems to be two clip-wire bundles on it, and a really short looking skinny(14ga?)ground wire connected to it.
has anyone here done this mod, and how long did it take? and if done correctly, will this help a bit with dimming headlites?
thanks.
Old Jan 3, 2005 | 12:22 AM
burp..s'cuse me.
Old Jan 3, 2005 | 08:01 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
are you running a secondary battery? If so are you using an isolator? other than that if not you can look at a ground to
Engine-Head+Block
ECU sometimes helps
Transmission
Frame
Those are where I did mine in my last car but i also ran a fully isolated supply for my stereo stuff.
Old Jan 3, 2005 | 08:02 PM
2 Da Max's Avatar
i think hes talking about hyper grouding kit?
Old Jan 3, 2005 | 08:06 PM
Terran's Avatar
I think the instructions posted here by kingrukus are the big three (though I'm not certain). Seemed like a good writeup for grounding regardless so I bookmarked it.
Old Jan 3, 2005 | 10:41 PM
okay thanks Terran
but seems like it doesnt really help that much aside from having a smoother idle...
i need this because my amplifier is dimming my lights like crazy...I originally was going for another alternator, but I was told that this 'Big Three' was almost as good for helping with dimming lights?
anyway, how many amps does our stock alternator put out?
Thanks y'all!
Old Jan 4, 2005 | 10:26 AM
2 Da Max's Avatar
so go buy a better altenator... do you have a capacitor?
Old Jan 4, 2005 | 11:17 AM
ya i have a cap, but its not enough for a weak charging system.
anyone in here change out their alt? and to what amperage rating?
Old Jan 4, 2005 | 04:06 PM
Terran's Avatar
I don't think that thread was in regards to a system though. It was just about a grounding kit. I'm not sure, but I think that is the big three, which should help with dimming lights. If you're really overpowered for your alternator then you will have to get a bigger one. If you have trouble finding one you could PM krismax as I believe he had a thread when he got one awhile ago. I think he got 200amps.
Old Jan 5, 2005 | 12:58 AM
thankx dude.
Old Jan 5, 2005 | 07:39 PM
joebangaa's Avatar
caps dont work, i took mine out. still have a half farad on my components amp that i'm too lazy to replace. i heard if you get a ho amp you shouldnt go over 200 otherwise it compromises the performance of the car
Old Jan 5, 2005 | 09:48 PM
l3ftonm3's Avatar
speaking out alternators, i posted last night asking what the output was, and supposedly gle and se have higher outputs.
Old Jan 6, 2005 | 09:10 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
i believe stock has 125 max
Old Jan 6, 2005 | 10:32 AM
mAxBaSs27's Avatar
i have a 220 amp alt i got from dom iraggi. if you have any questions bout the big 3 or anything with the alt then PM me if you like
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
