How to install a aftermarket amp with a facotry Bose System w/ Navigation.
Old Jan 4, 2005 | 01:32 PM
MaximaSE2005's Avatar
Here is my situation.
I just got a Kicker KX600.1, Kicker Solo-Baric S12L72 subwoofer, R/T 793-12 subwoofer enclosure and a PAC AOEM-NIS2.
My question is how do I install it? Does anybody have any helpful hints?
My main concern is whether or not I should disconnect my battery because I am afraid of losing the memory in my Nav.
I have a little bit of experience in installing a subwoofer with a built in amp in a 1997 Infiniti I30 but I had an aftermarket Pioneer instead of a factory head unit. Plus, I have not done anything to any cars in a couple of years.
I currently have a Smoke 05 SE with all options except for the Elite Package and would like to install it as professionally as I can.
All suggestions will be appreciated.
Thanks!
Old Jan 4, 2005 | 03:29 PM
Scope's Avatar
Im izz sexay
Does you amp have a High pass filter?
Old Jan 4, 2005 | 03:34 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yea, this is common. go to the audio shop and ask for a "hi/lo" adapter. or just simply ask a person about it cause there is diff names to it. its an adapter that gives you outputs for an amp. it hooks up real easy. a do it yourself defenatly. once you get the outputs for the amp wich is RCAs then run all the necessary wires to power the amp. (assuming you know about installing systems)
MikesChevelle
Nov 23, 2024 11:17 AM
melteye
May 16, 2016 12:02 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
Abdelrhman
Aug 17, 2015 12:16 PM
PhalC1
Aug 5, 2015 02:36 PM
