where to face the ports
i'm building a ported sub box for my 96 maxima and i'm trying to decide wheteher to face the ports to the back like the subs, or to the front, or up through the rear deck, anybody tried this before? which way will sound better, which way is louder?
Louder, hard to tell. Extending the ports to go through the rear deck might change how the box sounds. If you prop the box up so it's flat against the deck, you should be alright. But of course, you have the speakers back there.
Having a program would really help, that way it can make adjustments for extending the ports. It'll be louder having it go into the cabin itself. But it'll get annoying really fast.
Facing back might actually be your best bet.
Possibilty of some port whistle, but that depends upon what type of port you use. The slots are the best I believe. It won't really sound bad, unless you push your subs too far, and distort them. And after awhile, the air pressure does get annoying.
Port material is what I was actually going for. MDF that sucker all the way up. Or Fiberglass.
edit, I was thinking of the old days for some reason, with the stupid plastic round ports. Those things always gave off an annoying whistle.
if you cut two holes in the rear deck and put ports in them, with a rear facing single 12" would that increase the bass at all? Whenever i want bass, i open up the ski opening in the middle of the seat and it helps, but lets people see whats in my trunk if i forget to close it when i park.
why would you put 2 ports for a single 12? if you port it through the rear deck you will get more bass in the cabin, for example kinda like a suv. no one could really see through the ski hole unless there lying on your hood looking striaght through your front windshield
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
