builing a box for 4 8" subs (help)
Hey, i just scored 4 8" subs, and i would like to build a box to accomodate them all, and maybe an amp. Help me please because this is the first time ever building a box, and i dont know how to do it... I do know that i want a sealed box. (plywood, nailed together, holes for subs, and carpet?) Give me suggestions please
I have 3 JL Audio 8" subs in a single enclosure in my car. Check my webpage for some pics. Depends on the subs you're going with and how you plan to wire them in terms of the box layout.
this is the first time ever building a box, and i dont know how to do it... (plywood, nailed together, holes for subs, and carpet?)
-Robert
Sweet! Thats a good design, i like it! The only thing is that only one will be visible due to my rear seat not folding down, but i like the look of the amp on the box. The subs are "Power Acoustik". I believe they are old moddels because i have never seen them before, but they will have to do... (they were free) Does your system kick hard SEmy2K2go? because im not sure if i want to put in 4, or 3...
Why would you gentlemen prefer to run 3 or 4 eight inch subs compared to two 10s. You would get lowere freq and with a sealed enclosure its still a tight sounding bass. Just want to hear your opinions for the choice....now if you get them for free...well duh why the hell not...but I don't think I would ever go buy 4 eights to put in my car
Fs = RE is 22.8hz/Alpine is 33hz.
xmax = RE is 12mm/Alpine is 11.7mm
Sd = RE is 195cm2/Alpine is 339cm2
Based on this, the a pair of RE8's will play lower (Fs is lower) and louder (more surface area) than a single Alpine. This is taking into account using sealed boxes to give them the same Qtc. Changing the box will change the Qtc and yeild different results.
-Robert
Originally Posted by Robert_J
Not always true. It's all dependent on the subs T/S parameters. Compare the Resonant Engineering RE8 to the Alpine SWE-1041.
-Robert
-Robert
Look into Arc v2 8's or IDv38's as well-great drivers
I love the thought of sealed quad 8's with clean 250rms per driver, in a tall cabinet- no much depth utilized in the trunk, plenty of mounting space for amp's behind the box and left over trunk area- superb SQ....Ahhhh to many choices...
I love that thought too, but im cheap, and i dont want to buy a box for that, they have to be special made n ****, too much trouble, and money... Now if somebody knows where i can get a quad 8" box for 50-75 dollars, tell me please, cause that would be sweet!
Originally Posted by Irishmax99
dont use plywood and nails, MDF and predrill the holes
Originally Posted by slickrick
why not? do you know something that we all dont know about box building to prevent us from not using the wood glue to hold the box together?
so your saying plywood and nails is a good way to build a box??
love the avatar....very happy they're out on dvd now
one of my fav cult classics...
Typically, you'd use particle board or MDF (at least 3/4") I'd prefer MDF since it's denser. Usually you'd predrill the holes, basically to try and prevent the wood from splitting when you screw it together. Then you'd use some sort of wood glue to glue the pieces together. We used to use "Beatsnails". The wood will break before that glue separates. Then, after the box is built, you'd need to apply silicone caulking to seal the inside seams of the box. Then, a lot of times you'd stuff or line the inside of the box with Polyester fiber fill. Keep in mind, that when you design and build your box, this will ultimately determine how good it will sound. If you're unsure, or doubt yourself, have a professional build it. You could have the best subs, but in a improperly designed and built box, you just wasted $$$.
As far as sound wise. Typically 8's give you tighter, more responsive bass. BUT, that's not to say that 8's won't play low. It all has to do with cone area and displacement of air. We did cars with multiple 8's, in properly designed boxes, that could smoke 12's. It's all physics!
hmmmmm... so i need to buy mdf, wood glue, screwnails, i have sealant, and i have to buy dynomat spray to put inside, and then im set? my friend has a wood shop i can do all the cuting, and designing in
edit: it was pointed out i did not specify baltic birch in another post and people assumed just "plywood". its not the same at all.
hehe....
yea its a great movie, its been out on dvd for quite a while... i love that movie
birch ply and wood glue while clamping until dry is better than mdf and screws. birch is lighter, has slightly less damping, but is much stronger than mdf.
learn something new.....is it really safe for say like 1200 watts of power?
im sure it is. ask robertj. think about it... the screws just hold the wood in place to let the glue dry. if they did not, then why use glue at all? because 99% of people use some sort of sealant inside the box to keep it air tight anyway so nobody can argue that using the wood glue is for sealing it; its for the construction of it. wood glue is some crazy stuff.
As long as you are using a good wood glue and not liquid nails, then you just need to clamp the pieces together until the glue cures. However, if you are using liquid nails you should really use the screws since it never does completely cure and can be softened with heat.
-Robert
One last question before i give it a go... If i want to make a box for 4 subs, am i essentially making 4 separate boxes with 4 sides that are the length of the actual box?
__________
l__l__l__l__l kinda like that???
Subs face here
__________
Subs face here
Stagnet04
Sep 14, 2015 11:28 PM
